Optimal CAN AFR Bank 1 & 2 values..
05-05-2011, 12:11 AM | #1 |
Welcome to the Thunderdome!
13
Rep 141
What are the optimal CAN Air/Fuel Ratio values depicted on our chart 3rd gear 3000-7000? **Answer** from shiv..."There is no ideal AFR"
Here's what I'm piecing together so far..... 10.2:1 - Stock no tune 10.5-11:1 - Too rich (from shivs comment below) 12.0:1 - Tuned baseline 12.5-11.5:1 - Vishnu Map 1 & 2 normal range under load Found this from 2008: "There's no "ideal" AFR. There are guidelines and rules of thumb. But little of it applies to direct injection applications. What we do know is that traditional high boost turbo max power AFRs (10.5-11.0:1) result in over-fueling in the case of the N54." -Shiv What is the normal range and when will this diverge? What is logging this telling me? Can it tell me if I have a pre-post cat exhaust leak? Bad o2 sensors? etc.? Trying to paint a definitive picture of AFR and the value it poses in logging it....
2008 e90 335i, Vishnu V5, DCI, PWM METH, AMS FMIC, AR catless, BMS o2 sim, and HKS exhaust.
