All these codes, just limped.....
05-05-2011, 06:53 PM | #1 |
Rep 2,875
Hi
I need help please... 10702 - misfire cyl 2 (going to change the plugs) 12020 - ?? (have no clue, it's not on the N54 code list) 10740 - catalytic converter 1 inefficiency (?? I'm catless!) 10887 - outlet-vanos variable cam control test (??) 12544 - boost-pressure control, deactivation (WTF??) What should I do?! I'm out of warranty FYI..... TIA!
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
05-05-2011, 07:13 PM | #3 |
1750
Rep 17,960
Drives: A Lot
One of your Vanos solenoids needs to be replaced. Common problem with cars with more that 50k on the clock. When it throws a vanos control test code, it will always be accompanied by other codes. Luckily a vanos solenoid is less than $100 and takes 5 min to install. Might be worth doing both (intake and exhaust) if they are original.
05-05-2011, 07:17 PM | #4 |
Rep 923
12020 = 2EF4 which is "Thermostat characteristic diagram cooling, mechanical" whatever that means
EDIT: According to endtuning.com it is "Map Thermostat Mechanism Jammed" not sure that helps anymore |
05-05-2011, 07:28 PM | #5 |
Professional Moose Racer
316
Rep 7,509
Is there an EDU on how to change the vanos solenoid?
Visit my blog anytime: http://www.sfpayments.com
BMW Dream Team PNW Chapter, member #1 |HP Autowerks | AR DESIGN | BMW PERFORMANCE | STOP TECH | Volk Racing| AMS | ARKYM |
05-05-2011, 07:31 PM | #6 |
Rep 923
Not sure what EDU means, but there is a DIY here:
http://www.e90post.com/forums/showthread.php?t=486201 |
05-05-2011, 07:38 PM | #7 |
316
Rep 7,509
Thanks!
05-06-2011, 11:04 AM | #8 |
Rep 2,875
Where would be the cheapest place to buy the vanos solenoids?
I called BMW and they wanted $154 and some change for ONE! lol TIA
05-06-2011, 11:05 AM | #9 |
Team Zissou
3084
Rep 10,198
05-06-2011, 11:46 AM | #10 |
Rep 923
05-06-2011, 11:56 AM | #12 |
Rep 2,875
Should I just replace one, or both solenoids?
05-06-2011, 12:36 PM | #14 | |
Rep 1,279
Drives: 2007 e90 335i
Thats where I bought mine and I only replaced the exhaust, but not a bad idea to do both.
13.01 @ 107.6mph Mods: OETuning........
13.00 @ 108.89 JB4 Times |
05-06-2011, 01:25 PM | #15 |
Rep 2,875
Are you referring to the cat converter code? I thought there's another code for O2 sensors when they're bad, I believe I've had one like that before.......
Just don't wanna start ordering parts when I'm not sure that's the issue........
05-06-2011, 01:34 PM | #17 | |
Rep 2,875
05-06-2011, 01:39 PM | #18 |
52
Rep 428
Your o2 sensor is fine. That's just a cat code from running aftermarket (or fewer/no) cats. That's handled by CANclear periodically not not trigger any dash light.
