6mt shift bog/lag with 2.02 std (Cobb)
05-05-2011, 09:45 PM | #1 |
Rep 897
anyone else seeing this... dead spot-lag between shifts, am I shifting to fast too slow> is it a tune issue>
Feedback appreciated Last edited by Murf; 05-06-2011 at 06:00 AM.. |
05-06-2011, 12:47 AM | #3 |
Rep 644
I'm going to take a stab at this b/c I've noticed this as well. I think that the ecu pulls back the timing when you jump back on the throttle after a shift in order to reduce the chance of any tip-in detonation from a temporary lean condition.
I don't have any data logs or anything to support this. It's just a guess. |
05-06-2011, 01:53 AM | #4 |
Rep 1,809
Even stock the car has shift bog if you shift very fast from 3th to 4th, I tried it before getting tuned. However, with GIAC Stage 2 I can induce bog extremely rarely, and I could never induce bog with Stage 2 Race.
05-06-2011, 06:56 AM | #6 |
Rep 334
Man I have felt the bog and it looks like it happens to all tune no matter what, it depends on your driving style. One thing im doing is shifting from 3-4 between 6k and 6,3k.
R56 Cooper S
E92 335i E30 332is Burger Tuning, Evolution Racewerks and VRFS in Puerto Rico... |
05-06-2011, 07:15 AM | #7 |
Rep 3,460
Easy fix. I talked to.Cobb a out this the week the tune came out. I guess they didn't put it into the maps though. There's a flaw in stock programming that spikes timing as the rpms go down in Btwn a shift. Load is somewhere in the 40s and timing goes as high as 2x sometimes. They need to drop coming in that portion of the load table or implement a timing drop activated by the clutch switch.
05-06-2011, 07:35 AM | #8 |
Rep 897
Yeah this is only happening on high rpm shifts, anything under 45-5k is pretty smooth. One other thing i've noticed is a slight stutter when flooring it in a higher gear then the car takes off. Do you think im spiking boost and actually feeling throttle closure before boost tapers? Would running a 91 octane map ameliorate this?
Thanks again for the feedback, I just came from a B7 RS4 and feel like im taking a crash course in turbo tuning lol... |
05-06-2011, 08:03 AM | #10 | |
Rep 549
05-06-2011, 08:07 AM | #11 |
Rep 3,460
There are two forms of this bog. One is boost overshooting which cause throttle.closure....not harmful. The other is caused by these timing spikes. When you feel that bog what you are feeling is the car knocking. Hopefully some one at Cobb has some shifting skills and can slam.a.car into.gear like some users on here can.
05-06-2011, 08:24 AM | #12 |
Trance Life
315
Rep 4,706
I've had lots of bog/hesitation when flooring the car in low gear at high RPM with the Cobb. Car hesitates for a second, then takes off. Kind of like turbo lag...
Vanguard V2 Exhaust//Vishnu DCI//ACM Angel Eyes
05-06-2011, 09:13 AM | #14 |
Trance Life
315
Rep 4,706
Yes I did log...apparently I wasn't doing it right though. Someone told me you have to be in 3rd and then WOT. I have a couple of logs but the info didn't come out right. Oh well, the tune is gone anyways.
05-06-2011, 09:15 AM | #15 |
Rep 3,460
How. Didn't it come out right. Can you post what you have? Email me the file if you need help with excel
05-06-2011, 09:16 AM | #16 |
Trance Life
315
Rep 4,706
Can you PM me your email addy? I'll send what I have. I'm also no excel guru on top on it so I can't translate the raw data
05-06-2011, 09:23 AM | #17 |
Trance Life
315
Rep 4,706
Sent....now that I'm looking at it again the RPM's don't change...must have done it wrong
05-06-2011, 12:10 PM | #19 | |
Rep 1,708
Changing the timing table would mean reducing timing along a 1000rpm range in many load cells, since the speed and rpm of the shift would decide what load/rpm you hit. Anyway very curious on this. |
05-06-2011, 12:15 PM | #20 |
Rep 3,460
Hence the clutch switch timing reduction which is already programmed into the car. Sit a idle and watch timing.....now press the.clutch in and see what happens
05-06-2011, 03:52 PM | #21 |
Rep 1,708
