Procede V5 Code reading?
05-07-2011, 12:00 AM | #1 |
Rep 132
Hey guys, been getting lots of limp modes lately with the new V5 and I'm trying to read the codes but I can't seem to do so. I have the labtop hooked up to the USB, key in the ignition and procede connected, but I can't seem to figure out how to actually read the codes in the software. I've browsed the forums and looked at the Vishnu forums but still can't figure it out, any help would be appreciated thanks in advance!
05-07-2011, 12:12 AM | #2 |
Rep 6,631
add CAN DME Codes in your datalogging parameter. With Procede online with your laptop and ignition on, (engine off) press the gas pedal once. You'll see a check engine light and the codes will display under the CAN DME Codes parameter. Press gas pedal 3 more times to clear those codes.
E90 LCI N54 6AT
05-07-2011, 12:12 AM | #3 | |
1750
Rep 17,960
Drives: A Lot
05-07-2011, 12:13 AM | #4 | |
1750
Rep 17,960
Drives: A Lot
05-07-2011, 12:22 AM | #5 | |
Rep 132
05-07-2011, 12:26 AM | #6 |
1750
Rep 17,960
Drives: A Lot
If you have connection between your laptop and Procede, you should see a "CAN DME Codes" channel listed on the top right window of the software. This should flash some numbers after you require a code read. Once you clear them (command 2) and read them again (command 1), it will show 0.
05-07-2011, 12:30 AM | #7 | |
Rep 132
05-07-2011, 06:06 AM | #8 | |
Rep 2,320
p.s tryed with gas pedal and nothing happens no icons no codes nothing
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
