Helix turbos and procede
05-07-2011, 10:36 AM | #1 |
Rep 133
Just had helix turbos installed. Question for shiv - if I have full bolt ons - what is best map to run. Is there a custom map for upgraded turbos?
05-07-2011, 11:03 AM | #2 |
Rep 2,626
you should be more excited for someone who had a turbo upgrade
how is she running so far ?
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
05-07-2011, 11:43 AM | #3 |
Rep 2,875
There should be a 'upgraded turbo' folder within the Procede maps..........
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
05-07-2011, 12:00 PM | #4 |
Rep 7,377
with the helix just run the std. maps 3.30 . I do the same. Only RB turbos have a special map right now with different Boost control DC value. .
05-07-2011, 06:29 PM | #5 |
Rep 133
I will do a more detailed review later. Still trying to see what kind of max boost I can get. Having problems putting down power. I think traction control is cutting in too early. Seems much more agressive than my Dinan tune was (traction control intervention even with DTC engaged). Trying to progressively loosen rebound to see if I can get more grip. Hope I don't have a boost leak or have wrong spring in my diverter valve.
05-08-2011, 10:35 AM | #10 |
Rep 133
Thanks for the advice guys. Turned DTC off. Have an LSD. I need to see if the stupid Vishnu double traction control is on. I also have a very sensitive suspension. Small changes in rebound make a big difference. I may need to tweak to get more power to the ground. Yes there is a lot of power (and in this case a lot of torque creating the problem)
05-08-2011, 11:50 AM | #13 | |
52
Rep 428
05-08-2011, 05:01 PM | #14 |
Rep 133
Calvin. Thanks for responding. I lowered the rebound on my shocks and that helped a bit (to get more traction). I also tried running in stock mode and had no issues whatsoever. In fact difference was dramatic. The proceed seems to really be intervening (and cutting boost) a lot. Any way to completely disable procedes traction control and just rely on dtc / dsc?
05-08-2011, 06:06 PM | #15 |
Rep 133
I assume that setting traction control at 100% will completely disable procede traction control in all instances and have me rely solely on DTC / DSC?
05-08-2011, 06:14 PM | #16 |
1750
Rep 17,960
Drives: A Lot
05-10-2011, 09:26 AM | #17 |
Rep 133
UPDATE: I found that weird behavior I was getting was due to improper map upload. I reinstalled firmware and maps and most issues seem to be resolved.
05-10-2011, 04:20 PM | #19 | |
Rep 1,809
06-16-2011, 08:17 AM | #20 |
Rep 334
Have you dynoed the car?
R56 Cooper S
E92 335i E30 332is Burger Tuning, Evolution Racewerks and VRFS in Puerto Rico... |
05-26-2013, 01:18 PM | #21 | |
Rep 456
any more feedback on helix turbos? I am due for an upgrade, RB or helix or vargus
