E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Attention Auto tranny owners over 60K miles
Reply
      05-07-2011, 10:50 PM   #1
Turkeybaster115
Drives: 335I
I began slowly leaking tranny fluid right around this mileage. I'm currently at 82K, and the other day, I had my car parked for 3-days straight, when I noticed a small puddle of trans fluid. I did some research on the boards, and its not a matter of if you'll develop this issue, its when. Leaking trans fluid can be scary, as it can lead to lack of gear lubrication, and clutch pack failure. The mechatronic sealing sleeve, and transmission pan gasket, needs to be changed, a long with a full liter of trans fluid for top off. I had the service done today at my local shop, and purchased the parts and fluid online. Get yours done today, weather you see a leak or not!
Car on the lift, waiting for temps to rise
Fluid being pumped back in
Trans fluid = Liquid Gold! $$
Special thanks to Kfrazie1's very informative thread:
http://www.e90post.com/forums/showth...ght=trans+leak
      05-07-2011, 11:00 PM   #2
momstmg78
Drives: 335i sedan
I changed mine(pan, sealing adapter, and 6.5 quarts of lifeguard 6) at around 45k miles. It might be a placebo but I felt like it shifted better and was smoother.
I think I am going to do this along with spark plugs, cleaning valves with intake off, power steering fluid, and rear end fluid every 40k miles.
      05-07-2011, 11:28 PM   #3
antonio335
Drives: 335i
The girl of the poster looks nice
JB4, Macht Schnell DP, AA BOV, SCOOPS.STETT STAGE 2 OIL COOLER.
      05-08-2011, 12:00 AM   #4
cvc 22349a
cvc 22349a's Avatar
Drives: 335i
Mechatronic sealing sleeve replaced at 33k miles. Like OP stated, trans fluid leak noticable when the car hasn't been driven for a few days/weeks. btw, the trans fluid looks like motor oil, not the usual red atf.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS
      05-08-2011, 12:30 AM   #5
needboost21
Drives: E92 335i
Great write up, I will do this next week!
      05-16-2011, 09:53 PM   #6
kfrazie1
kfrazie1's Avatar
64
Drives: 335i
glad to see my thread helped out.
Montego Blue E90 335i
7" VRSF IC | OFT Tune | DCI | RB PCV | Secondary CAT Delete & CYBA 3.75" Tips | M3 Front | Mtech Rear | CSL Trunk | 219M | KW V1 | AA CP
      05-16-2011, 11:18 PM   #7
RR80
RR80's Avatar
17
Drives: F10 535i
Mine start leaking around 30k miles ! replaced both Mechatronic sealing sleeve and the pan. Changed the Trans fluid together, but I am using the ZF ATF fluid.
      05-17-2011, 12:23 AM   #8
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
where did yo buy the fluid online?
Why didnt you just replaced all the fluid ? When i changed the pan 6-7 liters were needed.
      05-17-2011, 01:01 AM   #9
acdHQK713K
acdHQK713K's Avatar
Drives: Car
All the fluid? Unless you are pumping it out of the torque converter you are only going to get around 6 quarts out with a simple drain.
AutohausAZ sources the fluid OP is using.
BTW mine leaked at 60k miles. Sleeve replaced by dealer, pan replaced by me.
      05-17-2011, 01:11 AM   #10
RR80
RR80's Avatar
17
Drives: F10 535i
I just drain the fluid out and fill in the fluid til the pan can't take anymore. it's about 5 liter~~! It will hurt the trans if you fill too much fluid!
      05-17-2011, 01:15 AM   #11
acdHQK713K
acdHQK713K's Avatar
Drives: Car
Car needs to be on and fluid at proper temp to fill it properly.
      05-17-2011, 01:43 AM   #12
RR80
RR80's Avatar
17
Drives: F10 535i
Yes, the car is on when I fill it up. Is that all ATF fluid are good on our trans? I use the ZF fluid because dealer use this fluid!
      05-17-2011, 01:45 AM   #13
acdHQK713K
acdHQK713K's Avatar
Drives: Car
There are several threads about ATF selection in the Maintenance Section.
      06-29-2011, 05:20 AM   #14
Samuel L Jackson
Samuel L Jackson's Avatar
Drives: 328i Coupe
How much does the mechatronic sealing sleeve cost?
      06-29-2011, 08:11 AM   #15
Magic-Man
Drives: N54
This should be covered under CPO warranty, no?
      06-29-2011, 09:02 AM   #16
enrita
enrita's Avatar
Sweden
161
yes of course. on realoem you can find prices of everything. you can also find most of the stuff on ebay.
      06-29-2011, 09:17 AM   #17
BlueLion
she likes the flavor......
Drives: A51-E92
2022 X3MC  [0.00]
had mine replaced two weeks ago at 56k.
E92 Montego Blue silfa718 ..::STETT CAI|ADVAN RS|WAGNER FMIC|MS DP|VANGUARD|PROCEDE|FORGE DV|BMS OCC|KWV2|MICHELIN PSS|OOS::..
      02-09-2013, 02:09 PM   #18
Mr_SDP
Mr_SDP's Avatar
Drives: 2012 335i F30 Sedan Manual
New to the forum. Have a 2006 325i with about 40k miles that i dont drive very often and noticed a puddle of trans fluid on the garage floor under the middle of the car just like many of you. I just want to know TRUTHFULLY how difficult this job is. Mainly because the STEALERSHIP quoted about $700 to replace the pan/filter and the mechatronics sleeve. So again how difficult is this DIY job? Thanks in advance for any replies!
P.S. I have an electrical engineering degree so I'm decent when it comes to fixing things. I've also changed the oil myself on this car if that helps in comparison...
      02-09-2013, 05:44 PM   #19
Wes335XI
Wes335XI's Avatar
107
Drives: 2008 335XI Space Grey
Had mine done back at 38,000 miles. Had a leaking tranny and rear differential. Everything done under warranty.
08 E92 335XI - Space Grey/Coral Red 11.80 @ 118.95mph - 470AWHP
2013 BMW 335XI MSport Alpine White/Venetian Beige
2018 WRX STi TypeRA
2022 X5 MSport Alpine White/Tartufo Merino - Inbound
      02-13-2013, 11:17 AM   #20
soldado331
soldado331's Avatar
Drives: '10 AW e90 335xi
i hadn't heard about the mechatronic sleeve and it being a good thing to change along with trans fluid service. thanks for the heads up OP. added to my project list.
Reply
e90post
