03-23-2007, 05:50 PM | #1 |
Rep 6,381
Lens for Landscapes
What lens to you guys recommend for landscapes that won't be too much (less than $400)?
I recently got a 75-300 lens that has been great for nature shots of birds and animals, etc. and just getting things far away in general but I would like a lens that can get much more in the photo, I guess I mean a wide angle so as to capture more of a panoramic shot? Thanks guys
Nikki
03-23-2007, 05:57 PM | #2 |
Rep 1,024
You have a Canon right?
330i Monaco Blue, Terra /w aluminum trim, SP, PP, CA, PDC, Nav, Folding Seats, Sat Prep European Delivery Blog Picture Gallery |
03-23-2007, 06:07 PM | #4 |
YUGO is my dream car
144
Rep 1,564
10-22mm from Canon, the best but will defintely be over $400.You can probably buy a used Tokina 12-24 for less then $400. Still a very good lens, especially for lenscape, given the 1.6x crop factor which is equivalent to 25.6mm on the wide end. The Tokina does have a higher CA compare to 10-22 EF-S
03-23-2007, 06:15 PM | #5 |
Rep 1,024
I've just been getting more serious about photography myself but I went with Nikon so I don't have too much specific advise on lenses. Seems like a prime might be best in that price range though, to get good quality glass but still not spend a mint. If you get something wide you can always crop the photos in post processing if you need.
03-23-2007, 08:27 PM | #6 |
Rep 981
+1 on the 10-22. It's SUPER wide. You have to watch out to not get your feet into the frame sometimes.
A little above your $400 limit though. The stock lens is pretty wide at 18mm. Why not just use that? If you're starting to see the shortcomings of it, then it's time to start saving for the 17-55 f2.8 lens. I have both the 10-22 and 17-55, but find I am using the 10-22 less and less these days.
2013 M3 (E93) - ZPP/ZCW/DCT
03-23-2007, 10:21 PM | #7 | |
Rep 6,381
Here are some photos from the 75-300 btw. I got some nice shots from sooo far away and they came out pretty clear. The first one was maybe 15 feet away but I'm bad with distance, and the bird was maybe 20 feet. Thanks guys
Nikki
03-24-2007, 12:24 AM | #9 | |
Rep 981
Can you try another copy? If you don't know anyone locally, let me know. Although I have the 17-55, I kept the stock 18-55 lens for when I sell the camera. If you need to borrow it for a few days, you're quite welcome. Either way, yours should still be under warranty, but it sounds like it might be broken to me.
03-24-2007, 12:27 AM | #10 | |
Rep 6,381
Nikki
03-24-2007, 10:09 AM | #11 |
Rep 6,381
Here is a better description/rant about the stock lens.
I think there is a problem with mine. Maybe you can let me know and see if I should send it to Canon: When it is in AF mode it "hunts" for a focus pretty much all of the time and unless I focus on something in front of me (ie the ground or something) and then move it up it will just continue to hunt or I have to turn it to MF to actually take a picture. It started happening when I'm close to an object but that's understandable and I would just switch it to MF or step further away. Then it started happening in low light settings and I got pissed. I'd be in a parking lot with an ok amount of light trying to take a picture of a car. I'm on a tripod with like an 8" shutter and I KNOW it can take the picture but it just keeps hunting. When I got really fed up is when I was on vacation and I wanted to take photos of the landscape. The mountains were too far away for it to see them I guess so anytime I wanted to take a photo I had to focus on the water, move the camera up, and then take a picture. The last straw was when some guy volunteered to take a photo of my boyfriend and I and we were literally like 10 feet away from him, if that and it wouldn't focus and after several tries I told him to focus it on teh ground, then move the camera up and take the picture and it worked. sadfgmd;nkghsfjgjhfdjdj I had a guy at the lens shop look at it and he said my settings were normal and he didn't know why it was doing that. What is going on??????
Nikki
03-24-2007, 11:26 AM | #12 |
Rep 6,381
BTW I was recommeded a 17-40 lens that I can get for $688.28
http://www.amazon.com/Canon-17-40mm-...4753527&sr=8-1 What do you guys think of that one?
Nikki
03-24-2007, 11:58 AM | #13 |
Rep 29,202
Yes, crop factor is 1.6 on XT and XTi (350D/400D), so 100mm is 160mm.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
03-24-2007, 01:39 PM | #14 |
Rep 981
1) Your stocker is broken. Mine definitely doesn't do that mounted on a 300D. Call Canon to see if you can have it switched out under warranty.
2) The 17-40 is an excellent lens based on reviews I have read. http://www.photozone.de/8Reviews/index.html http://www.the-digital-picture.com/R...s-Reviews.aspx You can't really go wrong with any 'L' lens. I spent the extra and went for the 17-55 because it is faster (f2.8) and has IS. The 17-40 is arguably the better investment being 'L' and EF mount and not EF-S. I just hate using flash, so f4 is too slow at usable ISO speeds on the 300D and IS on the 17-55 also really helps with this. Image quality is on par with any 'L'. Neither give you the same extreme wide angle of the 10-22 which goes for similar money as the 17-40. 17mm is approximately the same as your stocker. 3) As for letting other people hold your camera to take snaps of you and your BF, you won't be doing that when you have $1000 of glass mounted. That's what your P&S is for!!
03-24-2007, 02:53 PM | #15 |
Rep 6,381
Ugh he basically told me I'm using it wrong, I dunno
Nikki
03-24-2007, 05:11 PM | #16 |
Not Stock
160
Rep 2,774
03-25-2007, 11:20 AM | #17 |
Rep 981
Go straight to Canon. The guy at the camera shop probably thinks you're some noob that can't use a camera. They probably see a lot of this with digital SLRs. What you describe doesn't sound right and if you state that on the phone to Canon, I don't see how they could refuse a repair. You just have to be firm.
03-25-2007, 11:24 AM | #18 | |
Rep 6,381
Here is what the Canon guy told me to do, but he never really explained why. He said to rub a pencil erasor on the lens contact and use a microfiber towel on the body contact which I did. He asked me what mode I was shooting on and I said manual and he made me put it on any other setting so I did. He told me to put it on partial metering. Then he said to test it out. I did and it was still doing it and then he said to go to some tutorial on some website to learn more about the settings and that was it. Should I try calling back again and getting a differnt person? Also, as far as the wideangle lens goes, I think I want the 10-22. Is that a good everyday lens?
Nikki
03-25-2007, 12:02 PM | #19 |
Rep 6,381
Tell me if this sounds good:
I have the 18-55- I'll use this for macro since I don't want to invest in a macro for now I have the 75-300 telephoto- I'm going to use that for nature and sports Now I really want the 10-22 for wide angle, artistic shots, landscapes, buildings, people, etc. but if I can only get one extra lens for now do you suggest the 17-40 as a better all-around everyday lens?
Nikki
03-25-2007, 12:20 PM | #20 | |
Rep 626
03-25-2007, 01:08 PM | #21 |
Rep 1,024
The problem is, the price for the faster lenses goes up significantly. If she wants to spend more than she said at first ($400) I agree, there are probably better options. The 17-55 f2.8 IS that gripster mentioned retails for about a grand for example. That'd be a fantastic every day kinda lens but quite a bit more than the $400 limit.
03-25-2007, 01:51 PM | #22 | |
Rep 626
