Vishnu Procede PWM Meth logs
05-09-2011, 10:35 PM | #1 |
1750
Rep 17,960
Drives: A Lot
Hellblazer's car. Dyno from last week. Street Datalogs from today. No glory logs. Just random logs I took for my own use. Updated with newest BMW DME software 2 weeks ago.
2007 335 6MT 49,000 miles Procede v5 w/PWM Meth DCI 91oct 70/30 methanol/water mix This car makes over 400whp at 16.5psi. Consistently. With, quite literally, no recorded knock retard. The car is terrifically fast. No loud exhaust. No signs of obvious modification. Just another 125whp on tap. Ambient temps were pretty mild today. Looking forward to when it gets warmer. Same progressive meth mapping logic as we use for the older nonPWM kit (ie, boost/timing targets don't get aggressive until meth flow reaches its target.) None of the low/high boost switchover at boost onset can be seen. Meth reacts as fast as boost rises. And is trimmed back during throttle closures/DTC intervention. Or when the engine is still warming up. Even when jumping on the throttle at 4krpm (3rd datalog), boost never "outruns" meth flow. This means consistent knock resistance when transitions into and out of boost. Still playing around with the Meth DC% tables. I know many people think their PPS meth systems feel seamless. But they need to drive this Dyno: Street datalogs: Last edited by OpenFlash; 05-09-2011 at 11:01 PM.. |
05-09-2011, 10:38 PM | #2 |
Rep 284
Lol... I just hit the purchase button on the Meth kit before seeing this. I'll post more logs too once I get mine.
PROCEDE V5, AR CATLESS DP's, HELIX FMIC, ER CHARGE PIPE AND TIAL BOV, OHLINS ROAD AND TRACK COILOVERS, INJEN INTAKE, AWD TURBO UPGRADE, VISHNU PWM METHANOL INJECTION, AMS CATBACK EXHAUST, M3 FRONT SUSPENSION COMPONENTS,VOLK RE30 19X9F 19X10R W/ YOKOHAMA ADVAN AD08 265/275
05-09-2011, 11:10 PM | #3 |
1750
Rep 17,960
Drives: A Lot
05-09-2011, 11:49 PM | #5 |
1750
Rep 17,960
Drives: A Lot
05-10-2011, 12:02 AM | #6 |
Formerly (-(ellblazer420
48
Rep 703
Drives: 07 E90 335i M/T, 15 F80 M3 DCT
Yes!!! thank you shiv looks amazing.
Can't wait to feed my DICmobile some more DIC juice |
05-10-2011, 01:10 AM | #7 |
Welcome to the Thunderdome!
13
Rep 141
Never messed with meth before, screw the FMIC! Those temps are out of control.....dropped 10 deg c in 2 seconds.....21 deg C, thats colder than my A/C! Can't wait.....looks rock solid!
What is the "Debug Bite Meth" data channel log?
2008 e90 335i, Vishnu V5, DCI, PWM METH, AMS FMIC, AR catless, BMS o2 sim, and HKS exhaust.
05-10-2011, 01:28 AM | #8 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
05-10-2011, 01:58 AM | #10 |
Rep 7,377
This looks really great, i like most the seamless power without the obvious switch from map 1 to map 2 i am experiencing now. the change from 15.5 psi to 18,5 psi is quite brutal and cannot be used on a track. You also cannot predict when the change will happen since it depends on the flow.
Hopefully i can adapt this to my kit somehow.
05-10-2011, 02:09 AM | #11 | |
1750
Rep 17,960
Drives: A Lot
05-10-2011, 02:55 AM | #12 | |
Rep 7,377
05-10-2011, 07:57 AM | #16 |
Rep 461
Thought you were going to post logs @ low psi? Showing the benefits of "misting" under normal driving conditions. Not WOT.
05-10-2011, 09:11 AM | #18 |
Mastermind
71
Rep 1,360
Are you saying that downpipes and inter cooler are not necessary in terms of power gains or reliability or in what sense?
05-10-2011, 09:17 AM | #19 |
Rep 4,732
05-10-2011, 10:11 AM | #20 |
Roll Tide
591
Rep 2,345
If you're boosting 16.5psi on the stock turbos without resistance removal (DPs, specifically), won't that wear like hell on the turbos?
Can you do some logs/dynos on a IC/DP car?
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306 |
05-10-2011, 10:19 AM | #21 |
Rep 332
Why is methanol injection flow between 33 and 35? I have the labonte kit from Vishnu and my meth flow is around 13-14. What's the difference between the Labonte kit and the PWM? Is it essential to upgrade to PWM in order to get more power at high rpm?
05-10-2011, 10:21 AM | #22 | |
1750
Rep 17,960
Drives: A Lot
Running more boost will always stress the turbos more. But running full advance will drop EGTs considerably. Which makes life easier for the turbos in that respect. |
