Just destroyed my ECU...
05-15-2011, 06:45 PM | #1 |
Rep 493
After my first unsuccessful JB4 install I was trying to reseat the main ECU connector but since the ECU plastic shield was in the way, i disengaged the slider completely ...
Now the large ECU connector is seated, the slider is in my hand, and I can't seem to get the connector out of the ECU. I think I have completely f&***** over my engine.
'13 E92 335is
05-15-2011, 06:56 PM | #5 |
Rep 3,730
Try to put the slider back in the connector. If that doesn't work, just pull out out, going to have to use some force. If the clip is in your hand then it's no longer locked in and "should" come out. Your ECU is not screwed.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
05-15-2011, 06:58 PM | #6 |
Rep 493
How do I get the damn ecu unit seated with the slider considering that the ecu shell/plastic is in the way?
I can't seem to seat it correctly at all and it because the slider is making contact with the shell!
'13 E92 335is
05-15-2011, 07:13 PM | #7 |
Rep 2,590
It's not hard, just lift the ECU out of the shell by pushing on the two tabs holding it in. Now with it elevated about 4 inches you can slide the connector on then slide the ECU and connector back into the shell as one.
05-15-2011, 07:16 PM | #8 |
Rep 3,261
Exactly... if you can't figure out how to just release the tabs and lift the ecu out slightly then you should be no where near your car with any tools.
2022 BSM/FR M4 Competition X-Drive 2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD] |
05-15-2011, 08:58 PM | #11 |
Rep 493
I live in new jersey. i'm officially back to stock - gonna try to re tighten all of the connections tomorrow and re try it again, but If that doesn't work I'm gonna call a few nearby friends to see who can help me install it.
Thanks for the help though.
'13 E92 335is
05-16-2011, 01:45 PM | #13 |
Rep 291
Just be very careful trying to pry it off of there. I actually broke my connector (the whole side where the slider goes in just snapped off in my hand) trying to pry it out. I'm not even sure where to find the connector now since there seems to be about 6 different part numbers that are supposedly it. I was able to glue it back on and get the slider in, so it works, but I want to replace the piece next time I go in there in case I have to take it to the dealer or something.
05-16-2011, 01:58 PM | #14 |
Rep 1,000
I have the JB3 too and this makes me nervous everytime I go into the ECU. I might get a Cobb just so I don't have to deal with it. Need to do a little more reseach between the two.
05-16-2011, 02:01 PM | #15 |
Rep 493
FYI - http://www.n54tech.com/forums/showthread.php?t=6557
I dropped a screw driver in there last night so i'm going to go in today and remove the tabs and grab it.
'13 E92 335is
05-16-2011, 02:45 PM | #16 |
Rep 838
05-16-2011, 04:14 PM | #17 |
Rep 167
Yah, it's really not that hard at all. The large subconnector fastner does touch the edge of the ECU box but its not that big of a deal. There is enough room to connect/disconnect the subconnectors.
05-16-2011, 04:48 PM | #18 |
I6 + TT = FTW
110
Rep 865
^+1
After you get it the first time, it will be much easier the next time you need remove/reinstall. I took mine out this past weekend to take the car in for service, and put it back in today in about half the time as my first attempt. IMO, the most annoying part of this entire install is taking all the plastics off to get to the ECU. |
05-16-2011, 06:49 PM | #19 |
The Blue Beast
142
Rep 5,665
Don't bend any pins in your ECU...
Was told a new ECU costs $3000...
Cobb AP Stage 2+ | BMS DCI | UR Catless DP | UR Chargepipe | Tial BV 50mm | BSH OCC | ETS FMIC | Eisenmann Race Exhaust | KWv1 Coilovers | Volk TE37 TC Kline Ed. |
05-16-2011, 10:23 PM | #20 | |
Rep 2,314
OP: I'm sure there is someone near you that can give you a hand. |
05-16-2011, 11:05 PM | #21 |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
What part of nj? I might be able to give u a hand.
