BMS/CM exploring an inexpensive quick mount meth kit!
05-16-2011, 07:49 PM | #1 |
Joint Chiefs of Staff
4927
Rep 116,037
BMS has been posting various updates on an inexpensive engine bay mount meth kit they are playing around with. It's still in the prototyping / exploratory phases but some of the information is pretty interesting! The pump location and meth pickup would make for a very fast install and removal. The system would be triggered by the JB4 eliminating the need for a special controller and allowing more sophisticated meth metering algorithms and would use CM's new failsafe box to monitor flow. They are also working on some new nozzle mount ideas. The attached photo was an early rejected nozzle design but the idea of putting the nozzle under the diverter valve so it sits flush with the charge pipe would shave a ton of time and aggravation off meth installs and removals. Installing a meth elbow or expensive charge pipe is the most time consuming and difficult part of any quick mount meth kit install.
I'll post updates and such here as I get them. |
05-16-2011, 07:59 PM | #4 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
good job mike!
05-16-2011, 08:31 PM | #8 |
ElevenPointFive
327
Rep 2,450
Mike, looks like you and I will be doing another future meth config on my car
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC |
05-16-2011, 10:30 PM | #13 |
Rep 270
CAI intakes are not going to work with any under the hood Meth kit, not Vishnu not BMS (if they have one) unless you want to modify everything they are creating, its all about being right there by the charge pipes...
2008 335XI BLUE
