small issue /w procede, updating the stock ECU?
05-17-2011, 01:32 PM | #1 | |
Rep 731
Hello so the main question here is can you upgrade the stock ECU with out uninstalling the procede?
2nd question is can ONLY a dealer do these updates? The main reason I ask is because my procede v4 with latest firmware and automatic trans maps is having some hesitant shifts when its warming up. Im dealing with the same exact issue some other members were dealing with in the thread below... Did some research and this is what I found in this thread which led me to believe that I need to update my ECU: http://www.e90post.com/forums/showth...t+procede+maps Quote:
Thanks, Travis |
05-17-2011, 01:41 PM | #2 |
52
Rep 428
The software update, unfortunately, can only be done by the dealer. And if you haven't had your DME updated recently, it's definitely worth doing. Especially if you have a 6AT. You don't have to remove your Procede though since you are presumably out of warranty. It wont interfere with the DME update process since all the CANbus functionality is only active when the engine is running.
05-17-2011, 01:46 PM | #3 |
Rep 3,730
Did you do your Transmission Adaptation Reset in the command center?
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
05-17-2011, 01:57 PM | #4 | ||
Rep 731
I was planning on using my Dinan cert. local BMW shop, i know the owner and he is cool with all the mods obviously. Contential Imports. Quote:
My unit is unlocked so I can upgrade it to v5 if that will fix the issue, I just have been reading about some issued with the auto and v5 so I have been holding on upgrading until they have v5 autotune. Thanks guys, Travis |
05-17-2011, 02:07 PM | #5 |
Rep 3,730
You can do it with the V4....however you are missing out on the V5
Here is the comand center and how-to: http://www.e90post.com/forums/showthread.php?t=427976
05-17-2011, 02:30 PM | #6 | |
Rep 731
Thanks again, Travis |
