Occasional problem playing music from HDD
06-02-2011, 07:52 AM | #1 |
Rep 8,113
Very occasionally (happened twice) I've had an issue where music will not play from the hard drive. You can scroll through the tracks, artists etc. using the iDrive knob or the thumbwheel on the steering wheel and you can select different tracks but it simply won't play - the counter sits there on 00:00.
Only way I've found to cure is to switch off ignition and back on. Any ideas?
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
06-02-2011, 07:56 AM | #2 |
Rep 13,043
Drives: BMW M340I G20
If I select a track immediately after starting the car, it freezes up and I have to go out of the HDD section and back in. I think it's because the data takes a few seconds to upload upon first start up. Although it will play the track I was listening to when I switched the ignition off, if i leave it to do it's own thing.
06-02-2011, 08:02 AM | #3 |
Rep 8,113
Mine kind of does that insofar as it won't search for the first 20 seconds while it gets out of bed but this is different.
Only got about 1200 tracks loaded and plenty of spare HDD capacity.
Ian
06-02-2011, 08:04 AM | #4 |
Rep 13,043
In that case, sorry can't help Ian.
06-02-2011, 09:23 AM | #5 |
Rep 8,972
Not used the HDD, I just play straight off a 64GB USB stick in the armrest
The upload to the car HDD seems to be the worlds slowest connection, I gave up. But even off the USB stick it still takes 20 - 30 secs to start up, so I'm kind of glad the HDD still does that too. |
06-02-2011, 09:30 AM | #6 |
Rep 8,113
I started off using the USB in the armrest but transferring to the HDD seemed that right thing to do, as it was there
Starts off slow but speeds up.... Perhaps I'll go back to playing from the USB stick.
Ian
06-02-2011, 02:59 PM | #8 | |
Rep 1,800
Black 330d E90 LCI M Sport Saloon Auto. Privacy Glass, Cream Leather, 6FL, I-Drive/Nav/Bluetooth, Alpine hifi upgrade.
