Detailed my car but still have wax left and cant remove it, what should I use?
06-04-2011, 09:49 AM | #1 |
Rep 453
Hey guys, I just detailed my jetblack e92 few days ago and I put it in the sun and saw some white spots left on the side of the car which I cant wipe off with quick detailer.
Whats a good product to use to get rid of the remaining wax? thanks
HTML Code:
http://www.e90post.com/forums/showthread.php?t=454788 |
06-04-2011, 08:03 PM | #2 |
Search or ban.
32
Rep 364
If you still have wax remaining, that usually means that you applied too much. You should be able to get rid of it by buffing the excess wax out with a mf towel.
'06 325i Black // iDrive // Cold Weather Pkg // Terra Dakota Leather // Lux 5.1 AE LED // Comfort Access // Premium Pkg // Ray's Sebring 19x8.5 & 19x9.5 w/ 245.35.19 - Mich. PS2 & 275.30.19 - Conti. SportContact2 // Front Bumper Splitters // MSD Air Scoops
06-04-2011, 08:05 PM | #3 | |
Search or ban.
32
Rep 364
Btw, if you can't buff it out, try alcohol diluted with water. This will take off any wax on the area that it's applied on, so you'll have to rewax the portion that you sprayed.
06-05-2011, 12:33 AM | #6 | |
Rep 188
Marc is spot on. And chances are its probably the fastest method compared to scrubbing with QD and towels potentially marking the paint. Just be sure the area is clean so you dont wipe around any dirt or grit. Mike |
06-05-2011, 05:49 PM | #7 | |
Rep 453
thank you guys
HTML Code:
06-05-2011, 07:13 PM | #8 |
Rep 6,594
You just want some Isopropyl alcohol (aka IPA, rubbing alcohol). It's available at any grocery or drug store.
X7 LCI // Incoming C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo |
06-05-2011, 08:36 PM | #9 |
Rep 1,274
06-06-2011, 11:26 AM | #10 |
Rep 1,232
If you use an IPA wipedown please use the correct dilution so as not to harm your clearcoat if it dwells on there. Safest bet is to rewax the affected areas. Most likely you did not apply thin enough.
