06-09-2011, 02:32 PM | #1 |
I like cars
346
Rep 5,051
Willow Springs advice
I'm going to be shooting a track day at Willow Springs. I'm going to rent a big prime but I'm not if I should go with the 500 F4L IS or the 600 F4L IS. Has anyone shot photos out there that can provide advice?
My photostream: http://www.flickr.com/photos/racelap/
06-09-2011, 03:35 PM | #2 |
192
Rep 2,391
are you going to be in the seats or have access to the sidelines?
these were achievable with the 300/2.8 on full-frame. but i was on the sidelines in the "press" areas of the le mans. not sure what your track is like, but hopefully this gives you an idea. a 600 will get you a bit too close if you want to get more than just the car in your frame.
2009 135i | space grey | sport | navi | hifi | heated
dinan stage 2 software | bmw performance exhaust kw v2 | hotchkis front sway | vmr v710 |
06-09-2011, 03:36 PM | #3 |
Rep 7,389
If you're talking about the series I versions, then the 500mm will be much lighter. You can use the 500mm with the 1.4x TC to achieve a focal length of 700mm, which is about all you can handle without a great tripod with a gimbal head.
If you can rent a Series II, then the 600mm is much closer in weight to the 500mm and you might consider it. Do you have experience with super-teles? If not, there's a bit of a learning curve needed to get good with both.
06-09-2011, 04:03 PM | #4 | ||
I like cars
346
Rep 5,051
Besides the lens I plan on renting a Wimberley gimbal head.
06-09-2011, 04:08 PM | #5 |
Rep 5,742
Drives: 2019 M2 Competition
What event? If your talking about tomorrow make sure to get good shots of my black 1 series...has Dark Advans!
06-09-2011, 04:11 PM | #6 |
I like cars
346
Rep 5,051
Different event, in July. Though if I could make it tomorrow I would go. But I'm going to be at RPI getting my exhaust installed.
06-09-2011, 05:15 PM | #7 |
192
Rep 2,391
you might like a 400/2.8 or 500 then. i would think a 600 would be more for a football field for close-up of the close-quarters action, but i've only shot track like this once.
06-09-2011, 05:34 PM | #8 |
Rep 5,742
