Fellas.... I need some help. Install gone bad.
06-17-2011, 10:19 AM | #1 |
Rep 50
The situation : Installed AR downpipes last night. I have V5 and am running the 1/21 beta maps. Took the car for a quick test drive last night and it seemed to run fine although there was definitely more of what I presume to be wastegate rattle than I had ever heard before. Prior to this I never really heard the rattle that a lot of people complain about. THEN, started the car this morning and is started a little rough. Went for a drive and the metallic clanking sound is incredibly loud. Accellerating, decelerating, you name it. Very loud and very noticeable and continues up the through the rpm band if you are accelerating slowly. Now the car will only run 5 pounds of boost as well. I have very little power. What gives??
If you guys have any advice. Please advise asap. Thanks.... |
06-17-2011, 10:23 AM | #2 |
I sweat pheromones
206
Rep 2,103
My guess... Didn't clock them right. Not sealed properly. Loss of boost and now they're probably touching each other causing the rattle. Doubt it's your wastegates.
06-17-2011, 10:29 AM | #3 |
442
Rep 18,331
Please go back to the 12-17 maps and you will be good...trust me on this....The newer maps has a bug and makes the wastegates possessed!!!! If this doesnt fix it then the v clamp is making the wastegates stuck...try the uploading the 12-17 maps and if it persist then adjust v clamp
06-17-2011, 10:31 AM | #4 |
I sweat pheromones
206
Rep 2,103
06-17-2011, 10:32 AM | #5 |
442
Rep 18,331
06-17-2011, 10:36 AM | #6 |
Rep 7,377
the newest ones are fine ;-) not out yet though.
06-17-2011, 10:49 AM | #7 |
Rep 50
I double checked to make sure I had clearance between the 2 pipes and there was about 1/4". Rotate them any more and they would mate to the midpipes. The v-band clamps are seated and sealed properly. Is there a chance the wastegate actuator can hit the screw on the v-band clamp if it is not rotated or located in the proper location?
06-17-2011, 10:53 AM | #8 |
Rep 7,377
the only way is to lift the car and check everything again.
06-17-2011, 11:04 AM | #11 |
Team Zissou
3084
Rep 10,198
not just ok, they work beautifully! 5-10 and the latest non-released ones
06-17-2011, 02:05 PM | #12 |
This is it!!
16
Rep 672
It's must be the clamp or did you remove any bolt and didn't tighten it? The 1-21 map should have no issue with the rattle. Only the 3-30 and up has rattle issues. I don't experience any rattle issue on any of the newer maps but seem like alot of people do. I have the latest firmware from BMW so that might be the case?
DFW, TX. Current: 08' Cayenne GTS, 14' Boxster S, 12' CBR 1000', 04' Bayliner 2556
Sold: 2010 A4, 2008 335i, 2007 335i, 2006 M3, 2006 S2000, 1990 NSX, 1991 300zx, 1992 Supra, 1996 Prelude, 1981 CRX, 1980 Mustang. |
06-17-2011, 03:00 PM | #14 |
442
Rep 18,331
