Misfire at Idle?
06-17-2011, 12:56 PM | #1 |
Rep 160
Drives: 2007 335i coupe
Misfire at Idle?
My car has been misfiring lately at idle and I am looking for suggestions on how to alleviate it. I recently put downpipes on and changed my turbos for better condition stockers. I don't recall having this issue before I tore into my car. When I run it through the rpms it doesn't seem to have any issues.
I replaced my plugs less than 2,000 miles ago with new factory ones. I just finished running 2 treatments of techtron through my injectors. Two weeks ago I had my HPFP replaced under the recall and that cleared up a 6th cylinder misfire I had. When idling I hear a poping/pinging sound coming from the downpipe/turbo area that seems to happen randomly. There are roughly 10 misfires a minute. I do not have any check engine lights coming on but it still is bugging me that its not running properly. My car is a 2007 335i and has 67,000 miles on it and to my knowledge has never had the valves cleaned or the injectors replaced. I am running amsoil synthetic with less than 2,000 miles on it. Could my misfire be caused by carbon build up on my intake valves? Is this normal and I am just not used to it since these downpipes are new to me and the stock cats would typically absorb the sound? |
06-17-2011, 02:19 PM | #3 |
This is it!!
16
Rep 672
Do you have procede? If so try a different map. Also try to change your spark plug. I had misfire last year and the spark plugs took care of the issue.
DFW, TX. Current: 08' Cayenne GTS, 14' Boxster S, 12' CBR 1000', 04' Bayliner 2556
Sold: 2010 A4, 2008 335i, 2007 335i, 2006 M3, 2006 S2000, 1990 NSX, 1991 300zx, 1992 Supra, 1996 Prelude, 1981 CRX, 1980 Mustang. |
06-17-2011, 02:34 PM | #4 |
Rep 332
Drives: F30 340i Xdrive
Check your spark plugs again.
06-17-2011, 03:42 PM | #6 | |
Rep 160
I will check my spark plugs again to see their current condition and post my findings. I do not know which cylinder the misfire is on but I can clearly hear poping coming from the turbo/downpipe which I have corrolated to being unburnt gas igniting from the downpipe and turbo temp, does this sound right? I do not have any codes on the procede to help guide me. Also it seems to be more prominent when the engine is warmed up. I will also try swapping coils around to see its effect and report back. HPFP should be good since it was just replaced but that's not always the case. No codes are making me think its the injectors but maby, no real way to check that. |
06-17-2011, 04:47 PM | #7 |
Rep 6,773
Curious how u have all those misfires and no misfire codes or limp mode..does your piggy suppress the codes?? are you sure they are misfires..n not something else going on
I had one misfire then codes and limp immediately thrown..swapped the coil packs from bank 1 to bank 2..cleared the codes n the problem didnt reoccur.. |
06-17-2011, 05:14 PM | #8 |
Rep 4,771
Did you plug your o2 sensors back in? I knew a guy who forgot and the small open hole in each downpipe made the car sound like a boat at idle and those noises could easily have been mistaken for misfires.
Just a thought... |
06-17-2011, 05:19 PM | #9 |
Rep 160
Ya I have all 4 sensors in my downpipes. They made it a pain to get the downpipes in!
I'm pretty sure its a misfire, I can feel it when I'm in the car also. Its like the engine is stumbling, it shakes a little each time it happens then returns to normal idle. I'll check to see if the procede is covering a code up but I don't think it would erase that kind of a code. What else could it be? |
06-17-2011, 07:23 PM | #11 | |
Rep 1,473
No misfire codes, no stumbling while on throttle. No popping noises. I have no explanation for it either. Spark plugs have <3k miles on em. |
06-17-2011, 09:54 PM | #12 | |
Rep 6,773
I think the OP has issues at idle even fully warmed up??? |
06-17-2011, 09:57 PM | #13 |
Rep 1,473
Mine was a new phenomenon about a month ago. Doesn't bother me, just odd.
06-17-2011, 10:06 PM | #15 |
Rep 1,473
06-17-2011, 10:36 PM | #16 |
This is it!!
16
Rep 672
I been having Procede for a while now. I always have the code for misfire. I am not sure why your Procede does not have a code.
06-17-2011, 10:38 PM | #17 |
Rep 6,773
06-18-2011, 12:36 PM | #19 |
This is it!!
16
Rep 672
You misinterpret my comment. I have Procede and I know when I have a misfire because my laptop tell me so....
