Take a look at the service history and tell me
06-20-2011, 02:48 AM | #1 |
Rep 43
Looking at this used 2008 335xi.
I took the service history of this car, and not sure if any of you have idea what is the current condition of this vehicle. Please share with me. btw, this car still have 1 year factory warranty remaining. 2 year remaining CPO warranty. I am planning to drive less than 10K km a year *Note, I haven't included bulb/scheduled service history. ****First of all, orders are recent to old. Car sits 57,500 km now.**** 1. AZ-ZEIT ALT,NICHT VERWNDEN at 54,836 km (What is this service?) 2. Replacing high pressure pump at 54,836 km (Part #13517616446) 3. Checking injectors in fuel injection system and removing, scanning and installing or replacing 2 injectors as required at 54,836 km Injector (Part #13537585261) Decoupling element (Part #13537564751) 4. Programming control modules (high pressure pump) at 42,982 km (no part) (Is this software programming?) 5. Replacing and installing or replacing both solenoid valves at 42,982 km Solenoid valve (SOL V) (Part #11367585425) 6. AZ-ZEIT ALT,NICHT VERWNDEN at 42,982km 7. AZ-ZEIT ALT,NICHT VERWNDEN at 32,421 km 8. Replacing high pressure pump at 32,421 km High-pressure pump (Part #13517592881) ASA-Bolt (Part #13537582770) Set of profile gaskets (Part #11617547242) 9. Removing and installing or replacing stop pad with ejector for fuel filler flap at 23,280 km BUFFER STOP WITH EJECTOR (Part #51178228939) Anybody have idea? I am picking this up in a week and still have options not to buy if this car have/will have serious problem. |
06-20-2011, 06:07 AM | #2 |
Rep 229
Its got the typical 335 VANOS, HPFP and fuel injector issues.
The good news is that all the work's been done. The bad news: why have they had to replace the fuel pump twice? Was it at the same dealership? Why didn't they get it right the first time? |
06-20-2011, 07:32 AM | #3 |
Rep 5,040
the fuel pumps haven't been redesigned to correct the flaw - they just keep replacing defective ones with new defectives ones. Not surprised that it has failed more than once.....
06-20-2011, 08:28 AM | #4 | |
Rep 229
Then the OP needs to decide if he wants the fun factor of the 335 and the risk of these problems in the future. |
06-20-2011, 08:47 AM | #5 |
Rep 129
My 5 cents, look for 2007 335i. It appears that mid to late 2006 build date has a lot fewer issues with fuel injection. If this car is thE one you like, it is still under warranty so unless you live 200 km away from dealer or planning heavy mods, who cares.
But you can drive a hard bargain, for instance don't bargain for money, but rather set of new brakes that you will need in next 10k, new tires and additional snow tire package. Dealer lease return worth about $30k +/- $2k + 2k warranty. Last edited by Bcruskie; 06-20-2011 at 08:52 AM.. |
06-20-2011, 08:50 AM | #6 |
phr
25
Rep 354
Fuel pump replacement isn't such of a big deal with the 335's, iv gotten mine replaced 5 times now, and after the second replacement it stopped surprising me. Op i think you should go ahead and make the purchase, you will be very happy, the fuel pumps are covered until 200k so you shouldn't have a problem.
AZ-ZEIT ALT,NICHT VERWNDEN i am also curious with this service, never seen it before, what is it? |
06-20-2011, 09:21 AM | #8 | |
Rep 5,040
06-20-2011, 12:47 PM | #9 |
Rep 107
Probably didn't fail twice. The second replacement with injector work would most likely be the recall, where everyone's pump got replaced, failing or not.
06-21-2011, 06:39 AM | #10 |
78
Rep 1,208
Twice isn't too bad to be honest. I think the majority of us here have had it replaced at least twice already...
Besides, HPFP is under warranty for 10 years now. The latest recall was supposed to have fixed it though (so far so good for me). |
06-21-2011, 01:41 PM | #11 |
Rep 334
They have a recall on the High Pressure Fuel Pump....mine was replaced a couple months with their revised version. Didn't have any problems to begin with....but was replaced anyways.....and still don't have any problems.
E46 Retired....................................Project E92 SB 335i
