AR Downpipes Swap.. Help car vibrating much more than before..
06-23-2011, 11:49 AM | #1 |
Rep 69
Please help me..
I recently swapped the downpipes to AR design downpipes and the car is vibrating much more at still and its not pleasant.. How can i fix this issue? Thanks |
06-23-2011, 12:14 PM | #3 |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Check to see if they're touching each other or any other part of the underbody.
06-23-2011, 12:26 PM | #4 |
297
Rep 4,408
06-23-2011, 12:34 PM | #5 |
Joint Chiefs of Staff
4927
Rep 116,037
06-23-2011, 01:05 PM | #7 |
This is it!!
16
Rep 672
DFW, TX. Current: 08' Cayenne GTS, 14' Boxster S, 12' CBR 1000', 04' Bayliner 2556
Sold: 2010 A4, 2008 335i, 2007 335i, 2006 M3, 2006 S2000, 1990 NSX, 1991 300zx, 1992 Supra, 1996 Prelude, 1981 CRX, 1980 Mustang. |
06-23-2011, 01:44 PM | #8 |
Some say...
239
Rep 4,296
Drives: Fresh
Yes it is actually, resetting your adaptations with procede can help with a shaky idle. If you can,t hear the pipes hitting something I doubt that's the problem.
I have exhaust and an intake... |
06-23-2011, 02:18 PM | #9 |
Rep 6,773
06-23-2011, 03:24 PM | #11 |
Rep 3,730
Stop driving over the rumble strips or take your iPhone off vibrate.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
06-23-2011, 08:05 PM | #12 |
3442
Rep 79,211
That was what I was referring to, the OP never mentioned he heard metal on metal noise otherwise I would say there is clearly an install problem. He just said vibrating which would mean possibly a rough idle which could be related to other hardware like HPFP or injectors too.
06-24-2011, 01:55 AM | #14 |
Rep 1,948
i actually had this when i had my MS catless ones installed. After a week, went back and had car lifted to see what was rubbing. Turns out, there was a very slight rub. You could see the metal scrap. The installers loosened and adjusted and all has been well since. Mine was funny. If i turned the wheel to the right slight and tapped the brakes to move the car say an inch, the vibrating would go hence why i figured there was a rub. The engine would move slight and exhaust wouldnt rub anymore. Take it back to installers.
06-28-2011, 02:32 PM | #15 |
Rep 69
When I turn off the car after coming to a stop, something hits something underbody.
Also at first start up there is a noise like whissss and it goes away after a 2 mins. Hate. it.. |
