Intermittent Exterior Lamp Malfunction
06-26-2011, 09:31 PM | #1 |
Rep 3,714
I've been getting a random error/warning light for bad exterior bulb. When I check all the bulbs they seem to be working and the error goes away by itself after a while until it reappears the next time. Any idea what it could be? Is it common to have loose contacts on some bulbs that might cause this?
06-26-2011, 09:38 PM | #2 |
Chump
10
Rep 173
Same issue here... 2009 e90.
It went on and off for a while and now it's been stuck on the last 2 months and it doesn't appear any of my bulbs are dead. I have LED Angel Eyes, but they are working and supposedly error free. |
06-27-2011, 10:07 AM | #6 |
Rep 3,714
06-28-2011, 04:26 AM | #7 |
Rep 457
Had the same problem on my E46 330Ci. I had a warning light that a rear tail light was out. I changed them out with some generic bulbs.......Still had the warnning light....Went to the dealer and bought some"BMW" globes.....Warning light was still there.
I just put it down to a wiring problem with the car then tried to ignore the warning light. After 6 months whilst loading some luggage into the boot (that is trunk for the yanks) I realised that one of the license plate globes was blown. Changed it out. Warning light GONE. Thank F*** for that.
2008 E92 335i M-Sport | Sapphire Black | Sunroof | Creme Beige | Poplar Grey | Logic 7 | 6AT | 19" AG M359's | Michelin PS4S | LUX V3 | MHD V5 E40 | Steve AZ Walbro inline | Vishnu DCI | BMS CP | AR Design Catless DP's | Forge DV's | Helix IC | (Stock Cat. back) |
06-28-2011, 10:07 AM | #8 |
D.D.S.
31
Rep 460
doesnt the warning usually tell you where the malfunction is (i have idrive)? Mine kept pinging rear left bulb. i removed the bulbs in the rear and it was fine after that. Another time my right rear blew out, i used a golf umbrella to step on the brake and found the burnt out bulb.
06-28-2011, 10:19 AM | #9 |
Big Beaver Smile
2125
Rep 3,792
Your rear bulb holders probably need to be replaced. This is a known problem for coupes. When I had this problem in my '07 coupe, I found a TSB around here. They come loose and and you get the warning. It takes the dealer 10 minutes to replace both sides.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch Last edited by wrickem; 06-28-2011 at 10:24 AM.. |
06-28-2011, 11:25 AM | #10 |
Rep 277
Ditto, had the warning with all light still working they replaced bulb holders and it went away.
