BIMMERPOST Universal Forums Off-Topic Discussions Board Router/DNS help
      06-27-2011, 02:23 PM   #1
jpsum
jpsum's Avatar
Drives: 2010 TSX
Router/DNS help
We have a Linksys RV042 router at work and I have recently updated the firmware on the router. Ever since then, every time we try to go to a website, it will fail to resolve the domain name at the first try. But if I hit refresh afterwards, it will resolve it in normal speed. I did do a hard reset after the firmware update. This is driving me nuts, plus I'm getting complains from everyone at work. please help!
      06-27-2011, 03:16 PM   #2
MadDog
Careful, I Bite.....
MadDog's Avatar
Drives: 2006 325i
2006 325i  [7.50]
Reflash back to the previous firmware, if possible. If you don't need the fixes the new firmware provided, just stick to the firmware that works.
      06-27-2011, 04:09 PM   #3
solefald
Nigerian Prince
solefald's Avatar
Vatican City State
412
Drives: '11 F25
'11 BMW F25  [0.00]
or install DD-WRT, but only if you are sufficiently nerdy.
http://www.dd-wrt.com/wiki/index.php/RV042
      06-27-2011, 11:13 PM   #4
M3Bahn
M3Bahn's Avatar
347
Drives: M3
Did the IP address of the router change?
Sometimes a hard reset does not work if power and all cables aren't removed before reset.
The journey is the reward.
      06-28-2011, 08:06 AM   #5
jpsum
jpsum's Avatar
Drives: 2010 TSX
The IP didn't change. I backed up the settings and restored it after the hard reset. I didn't remove any cables during the reset though. I didn't know the you could do a hard reset without power to it. Is that right?
      06-28-2011, 08:25 AM   #6
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
^this
If that doesn't work, try the hard reset, if that doesn't work...come back
      06-28-2011, 09:17 AM   #7
talisman311
Drives: e90
Interesting..
Assuming your handoff is ethernet, you could plug the ISP connection into your laptop and see if you get the same issues. If not...well you've likely found your culprit.
You can also download wireshark and check the packets to figure out what's going on.
I'm with the other guys..unless there's a new feature I want or a bug that I'm trying to address, I like to stick with what works. That works on the large campus that I maintain and throughout my company.
2006 e90 330i | Black/Terra | 6MT | ZSP | ZPP | ZCW
      06-28-2011, 12:13 PM   #8
jpsum
jpsum's Avatar
Drives: 2010 TSX
Originally Posted by talisman311 View Post
Interesting..
Well, the setup is a bit more complicated. It goes from cable modem > RV042 Router (use as gateway only) > Switch. Then there is a windows server connected to the switch as a file and DHCP server.
I'll revert the firmware back to the old one and see what happens. The newer firmware was supposed to fix a VPN connection issue we've had.
      06-28-2011, 01:38 PM   #9
talisman311
Drives: e90
In that case it makes sense to keep the newer firmware.
I'd run an ipconfig /flushdns and try to hit the webpage again, and then try it via pinging an external hostname. If you run into issues each time you flush the local dns table, it could be that there's high latency from the ISP's DNS (assuming that's what you're using). If they gave you different DNS server IPs, it may be worth a try to use an alternate.
Is your DHCP server handing out the proper DNS server IP provided by your ISP? You could also try some public DNS servers.. google has some, but it's not good practice to send all your DNS requests to them.
      06-28-2011, 02:12 PM   #10
talisman311
Drives: e90
http://code.google.com/speed/public-dns/
Looks like google doesn't care if you use them.. Try it on your local machine and see if that helps. Read their SLA, terms, if you're ok with it.. update DHCP and have all the clients renew the lease to pickup the news IPs.
      06-28-2011, 02:16 PM   #11
talisman311
Drives: e90
I know I'm post-whoring now.. but I hope you aren't letting the average client be able to get out freely to the internet. Most, if not all traffic should be blocked and proxies, etc. be used to let the user traffic outside. Something to look into if you aren't doing it already for security.
      06-28-2011, 02:35 PM   #12
jpsum
jpsum's Avatar
Drives: 2010 TSX
It's a small company - about 20 people at this branch. There's no internet policy here. Nothing is filtered or monitored. I don't set the policy either. I'm just a project manager with an outdated computer degree trying to help.
      06-28-2011, 02:38 PM   #13
jpsum
jpsum's Avatar
Drives: 2010 TSX
I've tried 8.8.8.8 before on my machine and the problem is still there.
      06-28-2011, 02:40 PM   #14
jpsum
jpsum's Avatar
Drives: 2010 TSX
Tried the /flushdns thing, no change.
All the machines received the DNS without a problem.
      06-28-2011, 02:41 PM   #15
jpsum
jpsum's Avatar
Drives: 2010 TSX
I almost want to bring in my own cisco WRT54G router and temporary replace the RV042 and see if anything changes.
      06-28-2011, 04:40 PM   #16
jpsum
jpsum's Avatar
Drives: 2010 TSX
Fixed. Flash it back to the original firmware. But now I still have a VPN issue.
Wasted two days of my time. Stupid Cisco.
      06-28-2011, 05:04 PM   #17
solefald
Nigerian Prince
solefald's Avatar
Vatican City State
412
Drives: '11 F25
'11 BMW F25  [0.00]
Stupid Cisco.
Even though Cisco owns Linksys, Cisco does not make low end consumer products.
Erm.. let me rephrase that. Cisco does not put their name on low end consumer products
      06-28-2011, 09:43 PM   #18
MadDog
MadDog's Avatar
Drives: 2006 325i
2006 325i  [7.50]
Advise Linksys of the issue you had with that version of firmware. Perhaps they'll fix it in the next release.
      06-29-2011, 08:01 AM   #19
jpsum
jpsum's Avatar
Drives: 2010 TSX
I think that used to be the case. My $60 WRT54N has a Cisco logo dead center and a smaller linksys logo on the bottom.
      06-29-2011, 08:05 AM   #20
jpsum
jpsum's Avatar
Drives: 2010 TSX
Nah, they wasted enough of my time.
      06-30-2011, 12:25 PM   #21
ciscosmallbiz
Guest
n/a
Drives:
Router/DNS Help
Hi ipsum, We’re sorry to hear about your trouble with the RV042 router and the VPN. We understand your frustration and desire not to spend more time on this issue. Should you decide to pursue further troubleshooting, we encourage you to contact support at http://www.cisco.com/go/smallbizhelp <http://www.cisco.com/go/smallbizhelp> or check out the Small Business Support Community at http://www.cisco.com/go/smallbizsupport <http://www.cisco.com/go/smallbizsupport> for additional assistance. We have forwarded your experience onto our product team. Your feedback is helpful in improving future versions of the product.
Thank You,
Cisco Small Business Team
      06-30-2011, 04:10 PM   #22
OC3
Havin' a blast!
OC3's Avatar
Drives: 2013 M3 E92 Jerez Blk DCT ZCP
Use a real firewall/VPN box
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
