07-07-2011, 10:11 AM | #1 |
Rep 1,734
Basement Advice
The last couple days, we have had some pretty rough storms. Last night when I got home from work, I went into my basement to do some laundry and realized there was about an inch of water on 3/4 of the floor. The sump pump is working but the floor is not graded correctly so this water cannot drain to it. I don't have anything in the basement aside from the washer and dryer but last night I sucked up over 100 gallons of water with my Shopvac and I'm not going through that shit every time a storm rolls through.
I am thinking I am going to have to have a french drain or a B-Dry system installed. Anyone personally install one or have one installed? Any recommendations? |
07-07-2011, 10:17 AM | #2 |
Rep 10,309
Drives: A///MERICAN!!!
Typically the best action is to address the root of the problem rather than bandaid it. Have you gotten an estimate to fix the floor?
07-07-2011, 10:20 AM | #3 |
Rep 1,734
Not yet. I'm am going to make some calls today. Even if I fix the floor, the groundwater from around the house still needs a better way to drain. Even though the gutters are clean, I need to check if they are slopped correctly and actually carrying water from the roof.
07-07-2011, 11:33 AM | #4 |
Bimmerpost Resident Marijuana Consultant
486
Rep 3,202
Drives: 320i, 325xi, 335Xi, 335i, M3
Garage List 2010 BMW 335i [0.00]
2011 BMW X335i [0.00] 2006 BMW E90 325xi [0.00] 2011 BMW E90 335xi [4.00] 2011 BMW M3 E90 [7.00] 2006 E90 320i [0.00] |
An easy fix is to tape the seals of the windows in the basement from inside and outside. If you have a belco door in the basement as well, get some plexi glass and layer it on the downard part of the outer slope to keep water from running in and your good to go. this is how most people do a "ghetto fix" with this situation in queens lol. Ive never done it, but seen it executed successfully many times.
"AMG What! S-Line Who? If you ain't got that M I got no respect for you!" '06 Alpine Weiss E90 320i | '06 The Green Machine E90 325xi | '11 Alpine Weiss E90 M3 ZCP | '10 Silverstone X5M | '11 Alpine Weiss E90 335xi |
07-07-2011, 11:55 AM | #5 | |
Rep 2,014
07-07-2011, 02:48 PM | #6 | |
Rep 1,734
About 500 sq ft. The ceiling is about 7 feet and in order to raise the floor high enough for the water to drain to the sump pump, it's have to be raised about another 6" which I'd rather not do. |
07-07-2011, 02:50 PM | #7 |
Rep 2,014
07-08-2011, 07:15 AM | #8 |
Rep 338
French drains will help a lot, but do you know exactly where the water is coming in?
Does the ground stay fairly soft around the house? Do you have any gutters that terminate near the basement door or around the basement walls? |
07-08-2011, 10:03 AM | #9 |
Rep 1,734
On the back of the original house, there's an addition which was not built very well and a deck that surrounds it. The water is coming in basically up through the floor under the area where the addition and deck cover. The gutters to need to be addressed. I think I'm going to have to rip off the deck and see what under it. I bought the house three months ago so I'm still trying to decide on basics.
07-08-2011, 07:41 PM | #10 | |
Rep 338
Anyway, is there a crack in the cement that you can see the water coming through? or is it weeping through? If the gutters drain anywhere near that area you need to redirect them Where does your washing machine drain ? and your sump pump? maybe post a pic ....of your basement and some naked chicks |
