Sealant on wheels before mounting Tires
07-09-2011, 09:12 PM | #1 |
Rep 5,063
Drives: Black e92 335i
I'm not sure what is done during the process of mounting tires onto wheels, but would any of the process strip the sealant off my wheels.
I was going to do 2 layers of blackfire wet diamond on my wheels to protect them and make them easier to clean. Wondering if I should get my tires mounted before I apply the sealant or if it makes no difference.
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
07-09-2011, 10:03 PM | #2 |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
I would get the tires mounted first.
07-13-2011, 11:56 AM | #3 |
Waaka Waaka
41
Rep 486
If Possible apply sealant first. So much easier and you can get the hard to reach spots.
Then reapply once on the car in the typical reachable areas. |
07-18-2011, 04:55 PM | #5 | |
Rep 8,003
There is really no point in sealing the wheels before getting the tires put on. The tire shop will use grease and physical force which may strip off the sealant anyway. Personally, I would get the tires mounted first. Then, apply sealant to the wheels. Finally, mount them on the car. |
07-18-2011, 09:00 PM | #6 |
Rep 1,168
^^^^^ agreed! There is no point to sealing the area that is covered by the tire anyway. Are they large spoked wheels? if so, then you can easily reach your hand in there and apply/remove. If tight spokes, then remove the wheel from the car if you want to seal them! Personally, I would rather opti-coat them over BFWD if that is an option.
07-18-2011, 09:06 PM | #7 | |
Rep 5,063
Thanks for the responses guys, appreciate it.
