COBB - GIAC Data Logging
07-14-2011, 08:06 AM | #1 |
Rep 23
This is NOT a noob "which tune should I get" question
My car is essentially stock and I have no desire to chase horse power, just to pick the low hanging fruit with some easily addable and removable mods. After searching I have narrowed it down to either the COBB or GIAC. I'm currently leaning towards the COBB due to its data logging capability. The two questions I'm got are; - How good have people found the COBB datalogging? - If I went with the GIAC what are my options for datalogging? Thanks all and please please done flame me |
07-14-2011, 09:59 AM | #2 |
Rep 1,922
Drives: 2021 G80 M3
I'd go with GIAC. doesn't BT tool have logging capability?
'21 G80 M3
'11 E82 135i DCT (Gone but not forgotten) '08 E90 335i (Gone but not forgotten) |
07-14-2011, 10:15 AM | #3 |
Rep 1,034
I'm in the same boat.
1 benefit with Cobb is being able to flash and reflash in the comfort of your own garage. 1 benefit with GIAC is being able to change maps on the fly with the handheld changer. |
07-14-2011, 10:18 AM | #4 |
Rep 124
Reflashing a new map on a cobb takes about 90 seconds. You could pull over somewhere while you're out driving and do it if you really wanted to.
07-14-2011, 10:28 AM | #6 |
3442
Rep 79,211
I think you will be happier with the Cobb. You have the convenience of a flash at any time, you are able to sell it in the future, and its capable of logging.
Let me know if you have any other questions. |
07-14-2011, 10:33 AM | #7 |
Rep 1,034
07-14-2011, 10:47 AM | #8 | ||
Rep 13,583
Drives: JB E92 335i
You will get a whole lot more functionality and accessibility with the COBB AP. You do get FREE software and map updates for life that be downloaded straight from the COBB AP Manager software or through COBB's site. Not to mention that the COBB AP does allow for you to do live data logging, trouble shoot and scan codes, and of course switch maps on the fly as well! Installation is simple and it literally takes 10 minutes to download your stock map to the COBB AP and 8-10 minutes to flash your car to the stage 1 map. You can also export your stock map on your computer to back it up just in case you do ever lose your COBB AP Hand held unit. You can also export all of your data logs to your PC as well. Quote:
v201 v202 with alternate throttle response v203 Each one of these versions do have maps specifically for end users with 91/93 octane gas and a specific map for those in California/Arizona/Nevada as those states do have a different quality of 91 octane. You do have definitely a lot to play with to see which one best suits your driving habits! The stage 2 tune is also due to be released by the end of summer which can be downloaded for free as well! |
07-14-2011, 10:57 AM | #9 |
Rep 313
^+1 for the COBB. I was in a similar position a few months ago and decided to go with the COBB AP due to ease of future free updates and being able to log via the AP. Power, performance, smooth delivery, CONSISTENCY, and the ability to resale if you don't like it or get sick of it you can resale it, where as with the GIAC you are completely out the money you "invested" in your tune. With that said, I have heard a lot of great things about GIAC II. Again I would highly recommend the COBB AP if you are on the fence, worst thing can happen is you buy, don't like, then resale and lose $100-$200. I have the 202 alternate Stage 1 on my 2007 MT 335i and I love it. Can't wait for stage 2 to come out!
07-14-2011, 10:58 AM | #10 |
Rep 1,809
Of course the Cobb resellers will tell you to get Cobb. But did you read how many problems Cobb users had ?
If you get GIAC, you will have zero problems. You will just have more smooth power and that's it. You can log with a BT tool ($170 factory refurbished - it can also read and clear error codes reliably - it's a must anyway) but for Stage 1 I am not sure you have any reason to log anything...it just works as it should. The only reason I needed to log my GIAC Stage 2 Race was when dialing in the right methanol amount. |
07-14-2011, 10:58 AM | #11 |
Rep 348
07-14-2011, 11:15 AM | #12 |
Rep 124
If all you care about is reading/clearing a few codes and taking some logs then the cobb ap is more than enough.
07-14-2011, 11:35 AM | #13 |
Rep 112
I am a bit biased since I chose GIAC, but COBB has had its fair share of problems and like tcsdennab is saying, if you search around the forum those with GIAC has had zero issues with the tune. It's really a flash and forget process.
And if horsepower really is not the issue and reliability is, then I suggest you choose GIAC and a BT cable for logging. COBB stage 1 is quite aggressive to be honest and you will be boosting what many considers too high for stock. If you do decide to go COBB I would highly suggest you add a few mods to make sure you don't heat soak etc. |
07-14-2011, 12:04 PM | #14 | |
Rep 124
If your worried about reliability just do what I do, run a 91 octane map on 93. COBB 91 runs about 14.5-15psi max, GIAC stage 1 runs about 14 if I remember correctly, so they are pretty close in that respect. |
07-14-2011, 12:34 PM | #15 |
Rep 112
GIAC stage 1 runs about 13-13.5psi. I logged max 12.7psi in multiple 2-3-4 gear WOT runs with ambient temps of 60F, but I have an aftermarket FMIC.
07-14-2011, 12:58 PM | #16 |
Slow,fast,slow, then you die.
12
Rep 243
What is the diff on V201 vs V202?
I have tried both and this is my observation v201: more linear v202: on/off or exponential. is this about right? |
07-14-2011, 01:10 PM | #17 |
Rep 124
There are alternative throttle maps for v202 available on cobb's site. Std is the on/off your experiencing, v1 is linear, and v2 is linear with a more progressive onset. I run 91 v202 v2 currently on my AT. More linear response makes driving in traffic smoother but the power is still there if you want it. On top of that, you can always pop it into DS to get more of the on/off response when your really gettin after it.
07-14-2011, 01:34 PM | #18 |
Rep 23
All, I really appreciate your responses but can I ask that we don't get into discussion about the performance of one tune vs another as there is more than enough in this forum already.
I'm really interested in the datalogging. The main reason I'm leaning towards the COBB is the datalogging capability as it appears that the only other alternative to having a flash tune with datalogging is to use the BT for datalogging. The thought of having to secure a laptop in the car doesn't appeal to me which is why I like COBB datalogging capability. Is the BT the only stand alone datalogging option? |
07-14-2011, 07:53 PM | #19 |
Rep 2,002
I would get a BT tool anyway even if I went with cobb. From what i've read on here, there was some issues with the cobb being able to clear every code. I've found my bt tool good for maintenance stuff to like resetting my brake life etc. I wouldn't base your decision soley on logging.
That being said, you'll most likely be happy with either. I think the cobb stg 1 is a little aggressive stock, i've read about problems people have with it. Either way I know most tunes offer a money back period so if you don't like it, send it back.
ESS 650 ACM-R Upgrades |
07-15-2011, 09:30 PM | #20 |
Rep 23
Thanks all. After doing some digging on the internet I think my best option is to get a standalone OBDII logger like the Autoterra.
When I first need the BT tool I will get one. I have a local distributor so I shouldn't any problems getting one. Is there any other recommendations for an OBDII logger? |
07-19-2011, 06:21 PM | #22 | |
Rep 372
Our switching gives you the ability to toggle between various power levels on the fly, literally. Further, I don't believe that anyone has come close to us with a plug and play high powered flash tune to date. |
