A Sign Of Hpfp Dying?
07-19-2011, 03:46 AM | #1 |
Rep 151
hey guys, i just had my car for a lil over a month and recently the car's been having some bad cold start ups..then the engine light came on when i was driving last night and the screen showed "engine malfunction, reduced power". but after i turned off my car and turned it back on, the car was back to normal. is this a sign of hpfp going bad? if so, am i able to take it to the dealership and just have them fix it even tho it's not showing the code anymore?
07-19-2011, 04:26 AM | #3 |
Rep 151
07-19-2011, 05:29 AM | #4 |
Rep 1,307
Do you know the part number of the current HPFP in the car? If you have the invoice you should be able to see it.. Hopefully it's not the latest 446 pump because that would suck, meaning that the new pump still fails.
07-19-2011, 05:31 AM | #5 |
1 Stock M
76
Rep 1,650
Drives: Something Slow
Could be multiple things with the fueling system, but usually long cranks mean HPFP. The fuel pump is warrantied up to 120k. You shouldn't have any problems bringing it in, plus all of the information and codes are stored on your key FOB.
Veteran USMC/Iraqi Freedom
Current: E46 M3 Retired: 2009 E90 AW M3 Retired: 2007 E90 AW 335i. |
07-19-2011, 11:10 AM | #7 |
Rep 2,875
And you still bought the car? Huh? I would at least pick one without those symptoms prior to purchasing it.....
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
07-19-2011, 01:19 PM | #8 | ||
Rep 151
i already knew our cars have that problem so i wasn't surprised..i knew this would happen sooner or later. i bought the car because it had everything that i was looking for. |
07-19-2011, 04:16 PM | #9 |
Rep 1,307
07-19-2011, 08:15 PM | #10 |
Rep 233
