Custom made exhaust - too loud!!!
07-19-2011, 10:35 PM | #1 |
Rep 31
Did my own stainless steel exhaust but it is too loud, added 2 vibrant resonators but not much difference.
Any ideas on how I might quiet it down not giving up gained whp? I have cp-e catless downpipes and left the oem mufflers, deleted second cats. Thanks for any suggestions. |
07-19-2011, 10:53 PM | #2 |
Rep 2,854
could have used longer resonators i guess.
an X or H pipe to equalize should make it sound less raw too i don't see how that setup could be too loud with OEM mufflers and resonators though. maybe your expectations are unrealistic? |
07-19-2011, 11:05 PM | #3 |
Roll Tide
591
Rep 2,345
That is too loud? Wow. Seems like it'd be quiet. Check and see if the golf tee/trunk actuator mod has been done. If so, undo it.
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306 |
07-20-2011, 12:31 AM | #5 | |
Rep 31
I never thought it was going to be loud but it is, and specially at low rpms when it shifts I don't like the sound, it sounds like a Honda!!! (sad to say) you really think an x pipe will do a better sound? it doesn't have the golf tee mod. Thanks |
07-20-2011, 02:00 AM | #7 |
Rep 7,377
x-pipe or some 100 cell cats.
07-20-2011, 08:16 AM | #8 |
Rep 4,401
Drives: 2022 F97 X3M Comp LCI
i have a very similar set up... UR catless downpipes, secondary cats deleted and OEM mufflers. the only difference is that I DO have an x-pipe (but no resonators). I personally don't think it's loud at all. with the windows up there is a bit of resonance, but i do feel the exhaust can be louder. i think its a very good compromise.
try adding the xpipe. should help i think.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
07-20-2011, 09:58 AM | #9 |
Rep 1,155
We tried it this way prior to making our X-pipe. It's way loud.. Once you add the x-pipe in it makes the note a lot quieter. At least it did for our exhaust system.
Michael |
07-20-2011, 02:26 PM | #12 | |
Rep 31
And what is the real purpose of the X pipe, less? or better sound? |
