Any tuners with the ease of Cobb AP?
07-26-2011, 01:28 AM | #1 |
Rep 127
I've been reading about the tuners and tried searching for install details but didn't find much. Are any of the other tuners easy to use like the Cobb? I didn't know if the JB4 PNP was supposed to be as easy to install or not?
07-26-2011, 01:34 AM | #2 |
Rep 957
Theyre All Easy. 123 Abc.
07 335i- SOLD, and will be missed...
Parts for sale- PWM meth kit, M steering wheel, M shift knob, perforated e brake handle |
07-26-2011, 01:38 AM | #3 | |
Rep 202
Cobb GIAC, Dinan, etc. are flash tunes while JB and Procede are piggybacks so it's hard to compare. JB and Procede are easy to install but you have to go into the ecu compartment while Cobb is a flash tune and works by connecting it to your OBDII sensor inside the car. The JB and Procede each have install instructions on their websites. They are easy to install and I can install or uninstall my JB in 5-8 minutes. The Cobb you just connect, upload the software and let it do it's thing. With the JB and Proced once you physically install it your ready to go. The Cobb you have to wait for to upload it's programing. Both in other words are relatively easy but their method of installation is different and it all depends on what you are looking for. |
07-26-2011, 01:49 AM | #4 | |
Rep 127
07-26-2011, 08:15 AM | #7 |
Rep 1,809
I think the choice of tune should not be based on the ease of install. The first factor should be safety for the engine, with the buget, features, etc. following that.
07-26-2011, 08:20 AM | #8 |
Rep 68
Drives: passively aggressive.
Location: probably in a hotel thousands of miles away from home.
I cannot believe that some piggyback owners are trying to make this into a debate. I currently own the COBB AP and Vishnu PROcede and can say the following....
If you are looking for the easiest tune to use, it is undeniably the COBB AP. It's the easiest to install, remove, and update. There really should be no debate about this. Here is the question that should be asked to the people that disagree: Which tune would be the easiest for your mother to install/remove from your car if you had to instruct her to do it over the phone? There would be no reason for me to be nervous if someone else installed or removed the COBB AP on my car while I was not present. On the other hand, I would not want anybody else without any automotive experience to install/remove my Procede. Of course, if you are looking for the strongest tune possible (using meth, nitrous, etc.), then go with a piggyback. COBB AP: Even my Mother can install it. |
07-26-2011, 08:27 AM | #9 | |
Rep 68
Find out how the a piggyback controls the engine versus a flash and I don't think you'd be choosing the piggy. |
07-26-2011, 09:01 AM | #10 |
Rep 2,492
Piggyback systems such as the JB4 and Proceed will rewire you to gain access to your ECU compartment under the hood. A more realistic install timeframe is 45mins of manual labor each time you want to install/uninstall it from the car. This can be a big pain in the ass as you'd have to remove the piggyback everytime you pay a visit to your local stealership for service etc as they will check for it.
The COBB AccessPort on the otherhand can be installed/uninstalled directly from yhe comfort of your driver seat. You simply plug the handheld unit to your OBDII port and let it do its own thing. Also, a flash tune is always going to be best as you are actually rewriting the code on the car such as air to fuel mix ratios, timing, rev limiters, etc. You'll not only get more consistant power throughout the powerband, but there's a TON more features available with the COBB AccessPort. You do also have the ability to data log which will allow for you to check your air to fuel ratios, boost, and a bunch of other parameters. A neat feature is the ability to check your 0-60 and quarter mile times as well. It will also allow for you to scan, read, and clear the ECU of fault codes which makes it pretty much undetectable. Best of all, you do get FREE UPDATES for life. What that means is that if there are any revisions/additions in the maps available, you can download them free of charge. Its not like DINAN/GIAC where you will get charged an upgrade fee for each stage. The COBB team and its dealers are very active and do provide uppdates constantly. For example, there has already been three versions of the stage 1 tune available. Stage 2 is just around the corner and once its released, you'll get to download it for free! If you want a great deal, I'd highly recommend you send **********s.com a private message Last edited by awei130; 07-26-2011 at 09:27 AM.. |
07-26-2011, 09:07 AM | #11 |
Rep 100
I think not! If there is, I also would like to know.
'07 335i Cream Interior - Comfort Access, Sport Pkg, Premium Pkg, Navi
Performance>// Cobb - Dinan S2// BMS dci // AR Cattless // Scoops // ETS 5" FMIC Suspension>// M3 Links // Mich PS2 // HPA Koni SA coilovers // M3 Frnt Sway Bar // BMS Spacer 10mm & 12mm Cosmetic>// Lux H8 Amber Halo // Performance Kidney // MTech Bumper w/Smoked Fogs / Side Skirts // |
07-26-2011, 09:10 AM | #12 |
Rep 6,993
Drives: 15 F80 M3, 22 G01 X3 30i
ESSTuning is offering a device now that appears to be very similar to the Cobb - it connects via OBD port and uploads their modified software. Don't know anything else about it, though - have seen it in a couple of magazines.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
07-26-2011, 09:13 AM | #13 | |
Rep 68
Some of the common features have much better implementation on the COBB AP - such as datalogging and live data display, which just f'ing craps on the Procede and JB. However, I would never say that the COBB has "a TON more features" because it actually has less and I don't think that it will ever be able to do all that additional stuff that the piggybacks can do (steering wheel controls, meth integration, etc.). |
07-26-2011, 09:21 AM | #14 | |
Rep 2,492
07-26-2011, 09:34 AM | #15 | |
Rep 68
Map switching is superior on the piggybacks because: a) it's instantaneous and b) it can be done on the fly. I am trying to give an honest opinion of both products to consumers who are undecided. You are obviously a fanboy who cannot accept criticism of the product you purchased. I prefer my COBB over the Procede, but I am also willing to accept its disadvantages. Sorry, but the piggybacks will always have an advantage with meth integration over the COBB. Unless you know where to find the unused pins on the N54 DME which BMW specifically created for meth integration. |
07-26-2011, 10:13 AM | #16 |
Rep 2,492
I comprehended the post just fine and yes the COBB does have a better UI integration than any tunes that is available for the N54 at this point of time. I have personally tried the JB3/JB4, a custom Alpina tune, and the COBB tune on my personal car. I'm sure other members here will agree with me when I say that I'm not just a fan boy and am actually a pretty avid enthusiast just like yourself and then some. It's good that I was able to instill that passion out of you as it allowed for you to give your honest opinion about the JB4 which is great for this discussion.
07-26-2011, 10:33 AM | #17 | |
Rep 13,583
Drives: JB E92 335i
JB3/4 Install Process PDF Install guide: ETA 45-60 mins COBB AccessPORT Install Process: 20 mins |
07-26-2011, 10:36 AM | #18 |
3442
Rep 79,211
Cobb is surely the easiest to install.
However one can install a traditional piggyback in the same time as a Cobb AP once they become proficient at it. |
07-26-2011, 10:44 AM | #19 |
Rep 871
Just watched that Cobb install video, just to be clear.. when they say "power cycle the car to ON" does that mean ignition ON and engine OFF.. or fully ON with the engine running?
Fully Loaded |
07-26-2011, 10:51 AM | #20 |
Rep 68
07-26-2011, 10:53 AM | #21 |
Rep 871
Thanks, I'll be giving the Cobb a try next week. Can't wait to not have to get into the engine bay. At this point all the constant install/remove/reinstall of the Procede has basically left my air filter in place by maybe one or two screws.... all the other holes are stripped. Not to mention it's always a PITA to pass the USB cable through the firewall each and every time. Really looking forward to the ease of use of the Cobb.
Fully Loaded |
07-26-2011, 11:04 AM | #22 | ||
Rep 13,583
Drives: JB E92 335i
