Why are our turbos so quiet?
07-27-2011, 09:00 AM | #1 |
Rep 51
I've heard some cars with twin turbos that have a deafening "PSSSSSHHHHHH" sound...
TT Cobra (57s @ 15psi): Of course there's the ridiculous supra turbo "surge" between shifts. So, is it a matter of our turbos being buried underneath the engine? Size? Design / manufacturer? Boost level? I'm sure with different tunes and intakes you can hear ours differently. Just curious... thanks. |
07-27-2011, 09:08 AM | #2 |
I <3 My E93
181
Rep 3,259
Bc the turbos are small I guess.. And I don't think BMW wanted to have all that psshhhh whistling turbo sound on there "Luxury" brand, just my .2 cents
Bagged and Wrapped E93 335i
07-27-2011, 09:21 AM | #4 |
Rep 1,793
+1
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
07-27-2011, 09:30 AM | #5 |
Rep 262
Drives: 09 911 C4s
Correct me if I'm wrong, but that sound is from the BOV. Our cars have a quiet BOV, but you can get a louder aftermarket one.
07-27-2011, 09:48 AM | #6 |
Guardian of the Night
109
Rep 1,831
Drives: 2010 335i M Sport Coupe
Correct, you are hearing the pressure release (Blow Off) more than you are hearing the spooling of the turbos...
2010 335i M Sport Coupe -- Black Sapphire Metallic|Coral Red|Loaded|JB4 Stage 3|BMS DCI|VRSF DPs|Camaross 6k AE|Performance Gloss Black Grilles|CF Performance Spoiler|CF Quad Diffuser|Double Layer Black Chrome Quad Tips|CF Roundels|Smoked Reflectors|Red Cyba Scoops|193s Painted Lamborghini Metallic Dark Gray
07-27-2011, 09:57 AM | #8 |
Rep 4,110
Drives: BMW M3
Aftermarket BOVs are not expensive for the N54 ... JBSPEED sells one. Then it will be very audible.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
07-27-2011, 10:01 AM | #9 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
the cats on the DPs and the intake box muffle most the sound of the turbos. Put in DCIs and catless DPs and you will hear them spooling all the time.
07-27-2011, 10:12 AM | #10 |
Back in a BMW
205
Rep 5,208
And add in a BOV to have the full turbo sound experience...
Ian
07-27-2011, 10:13 AM | #11 |
Rep 1,625
Sometimes, I'm surprised by the complete lack of understanding of some of our basic turbo engine components.
Our turbo's are not quiet.. at all. They have very pronounced spool when you run DCI's. In stock form you can't hear it quite as much because they are muffled in the stock airbox. In cars that have DCI's and catless DP's you can very clearly hear the turbo's spooling... obviously, its that vacuum sounding "whoosh". As far as BOV's go, you do not hear them until you shift, or release the throttle. At which point they vent excess pressure in the line to prevent compressor surge. Our stock DV's essentially perform the same task but they redirect air back into the stock box so do not you hear the vent as clearly. Turn up the boost with some software though and IMO the stock DV's are fairly noisy themselves. Anyway.. OP That mustang TT is loud because it has an open atmosphere wastegate dump instead of a recirculated wastegate. That means when the car hits target boost, the wastegate opens to prevent overboosting and your basically listening to the raw engine note straight out of the exhaust manifold into the atmosphere. The open dump is different that in our cars because in a circ'd system the excess exhaust flow remains in the exhaust line and exits through the rear muffler. Pretty much only aftermarket setups, or high HP setups run open dumps. They are illegal for road cars because you dumping unscrubbed pollutants into the atmosphere. I can't hear anything besides crap music on the Supra vid, but what your probably describing is the BOV venting air.
2014 Individual /// M5 Competition AW/AB || Vorsteiner FF-103 || BMS JB4 || Meisterschaft GTC || RPI || IND || Challenge || Last edited by ///M3THOD; 07-27-2011 at 03:45 PM.. |
07-27-2011, 10:15 AM | #12 |
Rep 2,014
That is because those cars are using blow off valves. Our cars come with diverter valves. One releases pressure (BOV) and one recirculates (DV).
07-27-2011, 12:30 PM | #13 |
Rep 1,713
i know there are more knowledgeble people here, but the biggest factor has to be the size of our turbos. it is a tiny snail when you compare it to some other ones. bmw did a smart thing by adding a turbo that is so small it feels like NA, not much noise, pretty much no lag and it adds nice amount of power (though underpowered in its potential - thats why people tune it).
07-27-2011, 12:35 PM | #15 | |
Rep 6,773
07-27-2011, 12:44 PM | #19 | |
Rep 204
07-27-2011, 12:44 PM | #20 |
Rep 6,773
07-27-2011, 12:51 PM | #22 | |||
Rep 5,538
EDIT: "PSSSSSHHHHHH" sound (from OP post) is the whistling sound BOVs make Last edited by Kolyan2k; 07-27-2011 at 01:07 PM.. |
