HELP!
08-02-2011, 12:35 AM | #1 |
Rep 40
HELP!
I recently installed jb3 and bms dci and running 2.0 jb3 on map 3 with 91 octane gasoline... and i was going 120 on an open road with traction control off.. and the engine problem! loss of power light came on..
is this the hpfp problem.. or something i did... |
08-02-2011, 02:13 AM | #4 |
Rep 1,719
You need to plug in the USB cable to a laptop and the user software will tell you what they are. Best to have a look at the sticky (I think it is here but I usually look at the one on n54tech) and follow the instructions
08-02-2011, 02:26 AM | #5 |
Rep 40
are u talking about the one for jb3? if so do i need a bt cable?
08-02-2011, 03:28 AM | #6 |
E85 is my friend
19
Rep 224
BT cable is one way to do it, albeit the more expensive route. If your JB3 didnt come with the USB cable, then you need to order it from Terry@BurgerTuning. Once you plug the cable into the JB3, you can pull codes, delete codes, plus upgrade the jb's firmware located on the N54tech forum. BT cable runs $300 or so, but the jb cable is something like $5. Your choice!!!
//sparkling graphite metallic // sport package // logic 7 // m-tech wheel // HID fogs // LED angels // M3 style CF hood // matte black kindney's // AFE DCI // kittyless DP's // custom SS exhaust // Godspeed FMIC // 15ohm JB4// DV Mod //
08-02-2011, 03:42 AM | #7 | |
Rep 40
08-02-2011, 06:36 AM | #8 |
Rep 6,631
The jb3 does not offer code reading/clearing. You have one of three options:
1. Upgrade to jb4 2. Buy a bt cable 3. Read the codes using a code reader from an automotive parts shop such as autozone. My personal recommendation is upgrading to a jb4.
E90 LCI N54 6AT
08-02-2011, 06:26 PM | #9 |
Rep 1,719
Sorry OP i didn't realise the JB3 could not read codes. I am new here and have the JB4 and it will read ALL codes (as i understand) from the user laptop interface along with a propper description, not just the code. Hardest part is getting the usb cable from the ECU box through the firewall and into the glovebox. well not so much as technically hard just a bit tight for someone with fat fingers
08-02-2011, 07:48 PM | #11 |
Rep 40
08-02-2011, 07:52 PM | #12 | |
Rep 40
08-02-2011, 08:05 PM | #13 | |
Rep 1,719
To be honest sounds like you need a mechanic |
08-03-2011, 02:47 AM | #14 |
Rep 40
i have no idea how to tell if its poped out or not, the car feels kind of weird now when im driving it( doesnt wobble or shake).. but it isnt giving me any dashboard signs
