Another Vishnu Customer Car: RB turbo+PWM Meth+stock exhaust
08-03-2011, 12:59 AM | #1 |
1750
Rep 17,960
Drives: A Lot
A customer dropped off his 2008 6MT Sedan yesterday for a PWM retrofit kit. His car originally had our old PPS meth kit with a Stett Charge pipe.
Other mods include: -Upgraded FMIC -RB Turbos -Vishnu DCI -Procede Rev2 -Catless resonated Downpipes -Stock Exhaust We removed the old PPS kit and Stett charge pipe. The only thing that was re-used was the actual meth pump. We changed the pump's bypass spring and adjusted the bypass pressure to what we spec for the PWM meth kit. On-meth boost/IC% setting was 17psi/0%. Off the shelf map. Off the shelf meth kit hardware (two 1mm nozzles). We also swapped in a Rev2.5 (replacing his original Rev2). Installation went smoothly as usual. On the road, the car was unlike any other upgraded turbo car I've driven...... it was QUIET! The stock exhaust with the resonated downpipes made the car barely louder than stock. Even at WOT. But man did it move! Stock suspension made things pretty exciting A total sleeper. You wouldn't know the car makes this kind of power by just driving it around casually. But push on that pedal and the rear end squats and the car just takes off. And with such a quiet exhaust note, it attracts no attention by fellow motorists Pics: Maiden run datalogs: First 3rd gear run. Still some bubbles in the system: 3-4th gear run. 2-3-4th gear run. Happy engine! The factory catback does limit power/fuel consumption. Fuel trims are actually negative at WOT. On my car running the same map (but with no cats and an upgraded exhaust), fuel trims are moderately positive. Which means more fuel consumption and more power. But still, i'm pretty shocked by how fast the car is given it's under-the-radar status. Cheers, Shiv Last edited by OpenFlash; 08-03-2011 at 11:28 AM.. |
08-03-2011, 01:48 AM | #3 | |
Rep 1,311
The man who keeps the car and garden clean is on holiday Great info about the stock exhaust Last edited by R1000K3; 08-03-2011 at 01:56 AM.. |
08-03-2011, 03:26 AM | #4 | |
Rep 306
I can feel it as a clunking sound at low speeds and turns. I checked all components regarding the drive train , but all is good. Finally called my installer and he told me im not the only one with this problem with Bilsteins. Went to the shop this morning and we checked for play on the shock , its huge. They are now in contact with Bilstein to resolve the problem cause almost every PSS10 or the ones with ride control they installed , has this problem. Annyway good to see another RB vishnu car on the road
335I AT 2007. Vishnu V5 / UR CAI / HPF Intercooler / ER Charge pipe / Synapse BOV / Macht Shnell dp's / Vanguard catless exhaust / BSH occ / Labonte S4 Meth injection / Quiafe LSD / Full M3 suspension parts / Bilstein PSS10 / EBC brakes and lines / RB turbo's
08-03-2011, 04:07 AM | #5 | |
Rep 1,311
08-03-2011, 06:02 AM | #6 |
Rep 1,432
Good to know how RBs are working with stock exhaust. However, I would like to see the power that upgraded twins are able to deliver. Couldn't you show logs with more boost and more timing? Preferably with FBO rather than with stock exhaust. Either with ASRs or RBs.
08-03-2011, 06:10 AM | #7 | |
Rep 506
Sorry to get off topic. Car looks great BTW |
08-03-2011, 10:59 AM | #8 |
Rep 3,730
Hey Shiv,
Are you guys tapping the power for the pump on the + battery terminal....wonder where ya got the idea from Looks great, have fun with the car Anonemous. Still waiting for my turbos....hopefully Sonic can pop them in on Oct 1.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
08-03-2011, 11:19 AM | #10 |
Rep 377
I've had my pss10s on about 6months..still quiet with zero issues..however I don't have the electronic ride control..mine are manually adjusting..I usually ride on medium settings.I think with ride control version you only have full soft or full hard options and riding full hard on bad roads could be the culprit..hope yours stay issue free
2007 335i Coupe 6AT - Sports Package - Premium Package - Procede V5 Rev 2.5 - Vishnu PWM - Vishnu DCI - Vanguard Exhaust - AR Downpipes - Helix FMIC - 19" Avant Garde M6 Reps - Michelin Pilot Super Sports - Bilstein PSS10 - M3 Suspension Bits - M3 Sway - M3 Strut Brace - GP Thunder -Forge DV -15% Tint - Aero Lip
08-03-2011, 12:17 PM | #13 |
Rep 1,432
08-03-2011, 12:21 PM | #14 |
1750
Rep 17,960
Drives: A Lot
Nope... it's because of the open loop fuel mapping. This map was intended for a FBO car running upgraded turbos. Not a upgrade turbo car with an exhaust plug. The purpose of this test was to show how it behaved with the standard default map (no changes). Ideally, you'd want to dial back the fuel map to account for the the reduced VE of the engine. But in the case of a 17psi, big turbo car with a bit extra backpressure, it's not a terrible thing to have it run a bit richer during transients since the engine is seeing a bit more stress than it would with a free flow exhaust. Car drives great and is safely tuned.
08-03-2011, 12:34 PM | #15 |
I sweat pheromones
206
Rep 2,103
Question Shiv,
If someone runs stocks turbos + FBO + meth BUT keeps all stock dp/exhaust, could you still expect awesome gains or would you still consider the exhaust 'plugged' as reviewed above? Last edited by dbjb; 08-03-2011 at 12:47 PM.. |
08-03-2011, 01:00 PM | #17 |
Rep 1,476
08-03-2011, 05:41 PM | #19 |
1750
Rep 17,960
Drives: A Lot
With stock dp/exhaust, you will not make the same gains as you would if you had them upgraded. You would still be able to make considerably more power with just a meth kit/tune but it's all relative. Did I understand your question correctly?
08-03-2011, 05:42 PM | #20 |
1750
Rep 17,960
Drives: A Lot
08-03-2011, 06:09 PM | #21 |
The Engineer
27
Rep 329
Drives: AW 07' 335i
Few questions:
Shiv, have you seen anyone try and mod the PWM system to work with a Stett CAI? RB is out of St. Louis right? Anyone know how to contact him? |
08-03-2011, 06:18 PM | #22 |
Rep 2,291
I am pretty sure Rob Beck is out of St.Louis, I think the only way to contact him is through private message here or on N54tech.com
This link may help; http://www.n54tech.com/forums/showthread.php?t=5029
2jZ + RB26 + 4G63 + LS9 + N54 =
