Running N54 Without Engine Cover?
08-09-2011, 05:56 PM | #1 |
Rep 12
Has anyone done this?
I like the sound of the injectors, and I live in a hot *dry* climate so I figured it would be okay if I just left the engine cover off for extra cooling and whatnot? |
08-09-2011, 07:05 PM | #2 |
Rep 553
Just don't get water in the coil packs or you'll mis-fire....
Montego Blue E90 335i
7" VRSF IC | OFT Tune | DCI | RB PCV | Secondary CAT Delete & CYBA 3.75" Tips | M3 Front | Mtech Rear | CSL Trunk | 219M | KW V1 | AA CP |
08-09-2011, 07:35 PM | #3 | |
Rep 6,773
There is a reason why these covers are there.not a good idea to remove em.you want sound get catless DPs, exhaust, BOV etc.etc...u want cooling get an FMIC, methanol, upgraded Oil cooler, upgraded radiator..etc etc |
08-09-2011, 08:13 PM | #4 | |
Rep 660
PROcede REV3+OpenFlash "Custom DynoTune" //Vishnu PWM Meth kit//AIS Meth Tank//18" Forgestar F14//BridgeStone RE11//WaveTrac LSD n M3 Bushing//
KW V3 Coilovers//ETS 6.25" FMIC//MS Ceramic Coated 3" DPs//aFe DCI//M3 style body kits//HPF GEN2 Exhaust//Performance CF Trunk Lip//FFTEC walbro 450 inline pump kit// |
08-10-2011, 08:35 AM | #6 |
A Zip an a Double Cup
80
Rep 4,462
Don't waste your time...
PTF Tuned | RB's | AMS FMIC | AR DP's | HPF Exhaust | CP-E DCI | Apex Arc 8's | 235/275 Star Specs | |
08-10-2011, 11:03 AM | #7 |
Rep 516
why not if you know the risk.
you could argue the stock intake and all its parts are there for a reason...
07 e90 335i 13 mk6 GTI 13 f30 335i |
08-10-2011, 11:15 AM | #8 | |
Rep 1,625
Marginally better cooling.. if any...?
2014 Individual /// M5 Competition AW/AB || Vorsteiner FF-103 || BMS JB4 || Meisterschaft GTC || RPI || IND || Challenge || |
08-10-2011, 11:57 AM | #9 |
Rep 3,730
Not sure how you can put up with those loud ticking injectors (along with possible causing damage to the coils)? If sound is what you are after, just remove the cowling and screw the airfilter back on. If you do that, make sure the ECU box is sealed good and tight.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
