Can I use an auto diff on a manual car?
08-09-2011, 08:20 PM | #1 |
Rep 387
I have search but have not find an answer for my question.
I need to know if I can use the entire rear differential (not the pumpkin) from an auto into a manual car?? Are they interchangeable?? thanks Dr3K0 |
08-09-2011, 09:05 PM | #3 |
Rep 4,764
PM Harold at HP Autowerks. I don't know about the 135. There was a change on the 335 with some different sizes. Harold knows every detail. People do put the auto ratio gears in manual cars, usually when moving to an LSD.
08-09-2011, 09:15 PM | #4 | |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Either way, it sounds like he just wants to use the internals (although it's worded oddly because he said entire rear diff, but not the pumpkin). I second the notion to contact Harold at HPA, he knows everything and then some.
The i8 needs a V8 amirite?
08-09-2011, 11:39 PM | #5 | |
Rep 1,719
08-10-2011, 03:19 AM | #6 |
Rep 1,809
Simple, because the automatic differential has 3.46:1 gear ratio while the manual differential has 3.08:1 ratio so if you put the automatic differential into a manual car the car will accelerate faster (and have a lower top speed in each gear).
08-10-2011, 03:47 AM | #7 |
Rep 195
Yes you can. I did it to my car and I love it. I had it installed w my quaife LSD. When researching it I found someone who had done the calculations on the difference. Approximately a 12% increase in torque in every gear. It's a terrific mod. Only downside is a bit higher rpms at cruising speeds...about 400 higher w the 3.46 than w the 3.08.
2017 M2|LBB|Manual|Executive Package|Fabspeed SportCat|Dinan S4 Tuner w Big Turbo|Remus Exhaust|Dinan Intake|Dinan Intercooler|Dinan LPFP Upgrade Kit|Ultimate Clutch Pedal|BMS Clutch Stop
08-10-2011, 09:11 AM | #8 | |
Rep 6,773
check these guys out..they do it all day long. www.diffsonline.com |
08-10-2011, 02:43 PM | #9 |
Rep 387
I meant what I said. I want to use the 3.46 gear on my car. I can install an lsd later or at the time of the swap. The thing is if I can just swap the entire differential from the auto into the manual equipped car. Otherwise I will have to ether hunt a pre 9/07 or pay big bucks.
At the power lever my car is now I don’t need the lsd yet. If I can swap an auto diff first and then when the power is max out and need traction, I will save for an lsd. |
10-16-2011, 12:41 PM | #11 | |
Supreme Allied Commander
3893
Rep 54,605
Drives: F80 M3
If you have a 135i as stated in your profile, then the answer is maybe. The auto diff is smaller dimensionally so you will also need to auto drive shaft. |
10-17-2013, 03:52 PM | #12 |
3893
Rep 54,605
Drives: F80 M3
02-20-2021, 11:16 AM | #13 | |
Rep 3
Xdrive 6sprred Manual
I appreciate if you confirm |
