Cobb has me confused:
08-10-2011, 11:21 PM | #1 |
Rep 2,253
From what I understand, cobb can fully erase codes. However, upon research, they can only remove codes in the ECU not the BLACK BOX or DME.
Therefore overboost codes and other traces will be left in those areas flashing to be caught. Cobb CANNOT erase/ clear the dme or black box and that is a fact that I learned over the phone. Can the bt tool erase the parts of the DME and BLACK BOX that cobb is UNABLE to clear? Thanks Last edited by E92TTKING; 08-11-2011 at 01:29 AM.. |
08-11-2011, 12:41 AM | #2 |
Rep 660
Oo wow, i wanna find out too
PROcede REV3+OpenFlash "Custom DynoTune" //Vishnu PWM Meth kit//AIS Meth Tank//18" Forgestar F14//BridgeStone RE11//WaveTrac LSD n M3 Bushing//
KW V3 Coilovers//ETS 6.25" FMIC//MS Ceramic Coated 3" DPs//aFe DCI//M3 style body kits//HPF GEN2 Exhaust//Performance CF Trunk Lip//FFTEC walbro 450 inline pump kit// |
08-11-2011, 12:44 AM | #3 |
Indian Stig
29
Rep 1,002
Drives: '03 540i M, '11 Ducati M796
DME = ECU
2008 E82 N54 || Stage 2 -------- Gone to a good home. |
08-11-2011, 03:39 AM | #5 | |
Rep 660
i don't think so...
08-11-2011, 03:58 AM | #6 |
Rep 549
Who told you they can't and where is this black box located?
The person who told you, should probably know where these values are logged. So where are they logged? I know for trucks, semis they store logg values for everything, and they logg a lot. No tuning solution get's past them. Granted it's a lot more money so they are likely to look harder. And as Kamal said, DME is the same thing as ECU. Lot's of comments on things they can't do. Weird since they have been in market since early 2011. Others still have problems and release updates every now and then, having sold tunes for a lot longer than that for the n54's. |
08-11-2011, 04:02 AM | #7 |
Rep 7,377
Cobb, piggybacks, bt cable, they all clear all codes/shadowcodes in the dme/ecu. If this wasnt the case half people here would have lost their warranty.
08-11-2011, 08:59 AM | #9 |
Rep 1,244
08-11-2011, 09:18 AM | #10 |
Rep 7,377
I also would like to know where this info came up "upon research" .
08-11-2011, 09:23 AM | #11 | ||
Rep 51
Welcome to e90post I guess! :sigh : |
08-11-2011, 01:49 PM | #12 | |
Rep 1,244
http://www.e90post.com/forums/showthread.php?t=570989 |
08-11-2011, 11:34 PM | #15 |
Rep 8,835
WUT
I think you are confused. DME = ECU. I don't know what "black box" you are talking about and no piggyback stores codes in the black box etc... Codes are triggered in the DME/ECU and can only be erased in the same area. All the piggys, Cobb and the BT tool can clear these codes now.
08-12-2011, 06:06 AM | #16 |
Rep 1,244
I don't pretend anything...I pay attention. If you're seriously worried about over-reving your car or doing a money shift, that's your own fault and not the tune. Why don't you do more research (and use the search feature) rather than starting more threads that have been answered hundreds of times.
08-12-2011, 11:54 AM | #17 | |
Rep 1,244
I could be wrong, but the black box is part of the ECU that stores in a different bank. With that being said, it would take something really serious like violating a rev limit or doing a money shift to be held against you. Again, that wouldn't be the tunes fault, but rather driver error. If your local dealer sent your ECU to BMW, I'm sure there is a chance they could find anything. (I'm speculating on that, but it seems reasonable to me.) Usually, it takes something really big for your local dealership to send the ECU to BMW. I've brought my car in for several issues and always uninstall my Cobb AP before hand. The last time they spent a whole day doing diagnostics on my car and found nothing related to the tune or any codes from it. |
08-12-2011, 12:24 PM | #18 |
Rep 649
i been running cobb since 07 suppored realeased i have had so much warranty work done since..
bmw never says anything to me and i have DP's |
08-12-2011, 01:15 PM | #19 |
Rep 43
I was fairly sure, but I sent an e-mail to Terry of Burger Motorsports. His response regarding ECU, Black box logging of the JB4 was fairly simple:
JB4 has hidden code read/delete built in. No need for BT. |
08-12-2011, 01:53 PM | #20 |
Rep 5,876
No such thing as black box LOL there are diagnostic trouble codes (DTCs) and shadow diagnostic codes...shadow ones don't show up on your generic code readers as they're BMW only codes...BT tool can read them, procede and jb4 can read them, cobb ap reads them...done...all of these tools/piggies/cobb ap can/will clear ALL codes weather they're shadow or not...no need to worry..
08-12-2011, 02:30 PM | #21 | |
Rep 1,051
The stored "historic" codes are what you are referring to those that are logged in the "black box." This means that even if a code is logged/stored etc, it can be cleared as long as you are running our latest BETA firmware update. Check our thread for details on this update and how to go about getting it. We are still not convinced that there IS indeed a black box as it is being described here. While it is certain that the DME/ECU is able to log codes we now have the ability to clear those codes. Thanks again and please let us know if you have any other questions. Travis COBB Tuning |
08-12-2011, 03:34 PM | #22 |
Rep 2,991
lol @ black box.
as if it wasn't bad enough that bimmer owners think this car is some magical unicorn, some believe it's a plane too HAHA !!!!!! |
