Forge dv's with stock charge pipe
08-12-2011, 10:49 PM | #1 |
Rep 575
Anyone ran in into some trouble doing it ? I know it'll fit perfect and all, but anyone detected that it maybe more leak prone that way ? Thanks
08-12-2011, 11:11 PM | #2 |
Rep 468
08-13-2011, 04:22 AM | #4 |
Rep 1,065
Drives: RB PWRED E90 N54 6MT
They work totally fine together!!
RB Turbo/Procede V5/Vishnu PWM Meth Injection Kit/Vishnu DCI/AR Catless DP/AE Performance Exhaust(Sold)/Helix FMIC/Forge DVs/Rixster Vent Boost Gauge/Wavetrac LSD/KW V3/ACT Street Clutch Kit
08-13-2011, 07:54 AM | #5 |
Rep 1,041
Well, I run the new type Forge DV's and I had nothing but trouble with boost leaks from both connectors, and I had a "professional" put them in. The fit was simply put: terrible. They wouldn't lock correctly into the stock chargepipe, and moved around, blowing partially out under even relatively low boost/pressure. And yes, I did check the O-rings, and ensure that the lock-ring was turned correctly.
Only after buying and installing an aftermarket chargepipe did I get rid of the boost leaks.
E92 335i 2008 Space Grey 6MT | Pure Stage 2 turbos | Motiv PI | Trueform Tech Intake | Quaife LSD | M3 Suspension kit | Öhlins Road & Track Coilover | DEFIVfab N54 diff lockdown kit | COBB PTF E85 Map | Fuel-It Stage 3 LPFP | NGK 5992 plugs | Wagner FMIC | Wagner 3" DP | Milltek exhaust | Tial BOV | SPEC Stage 3+ clutch | SPEC Steel SM Flywheel |
08-13-2011, 01:00 PM | #6 | |
Rep 575
08-13-2011, 01:03 PM | #7 |
Rep 6,773
I am using the "new type" w the stock charge pipe..I had a pro put em in b/c I was worried about boost leaks as well..1 yr no issues..i find that there is more of a tendency for leak w an aftermarket charge pipe than w the stock one
08-14-2011, 09:01 AM | #8 | |
Rep 1,041
I had some 30FF codes with the green springs (standard), but that all went away with the yellow springs installed.
08-15-2011, 04:41 PM | #10 |
Rep 6,773
08-15-2011, 09:32 PM | #11 |
Rep 1,465
My issue was...under 10 minutes the charge pipe snapped in half. I would suggest getting the STETT charge pipe or something similar due to fact that aluminum. The price of the BMW pipe is very close to an aftermarket one.
11 E92 M3 DCT Jerez Black ZCP...Eisenmann, Dinan, Fabspeed, IND, LUX
09-20-2011, 08:45 AM | #12 |
Rep 575
That's weird, ran my chargepipe up to 19psi with no issues. However one of my dv's is slightly leaking.
09-20-2011, 09:02 AM | #13 |
Mad Linux Guru On The Loose
1130
Rep 5,400
Stock charge pipe with forge DVs. No issues here either. I had no issues with stock DVs either, but I got an amazing deal from Forge directly, so I could not let it pass.
