JB4 #5 Misfire solved.. plug question..
08-20-2011, 03:02 PM | #1 |
2007 335i E92
44
Rep 624
Started having cyl 5 misfires when the JB4 was on.. no problem when off.. so swapped the #5 & #1 coil and dropped a new plug from the dealer in #5 and all is well now. Going to get the full set of new plugs now, question is whats the difference, if any, between these two sets ?
http://www.ecstuning.com/BMW-E92-335...arch/ZGR6STE2/ Here's some pics of the one I removed.. have about 31k on the car now, 6k of it with me.. guessing prior owner had JB+ because the clip was already broke
2007 335i E92 AT - MHD E85 Flash, xHP Stage 3 , MR5 Intake, VRSF DPs, VRSF 7in FMIC, ER CP, Fuel-It Stage 1, RB PCV, UUC Corsa Exhaust, BL R8 Coils, Sachs SRE Coilovers, M3 Control Arms, H&R Sway, BA Diff Lock, MDF Scoops, Tint, CF Hood, Mini Battery :: 2011 X3 xDrive 35i - MHD Stage 1, Alum Charge Pipe
08-20-2011, 03:21 PM | #2 |
Rep 2,875
Probably just get the Bosch, the cheaper one of the two, as the OEM plugs are Bosch also. I don't see the point of paying an extra $50 for the other ones......just my .02
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
08-20-2011, 03:22 PM | #3 |
Rep 2,875
Is that oil or gasoline on the thread of the plugs?
08-22-2011, 04:07 AM | #5 |
Rep 29
Drives: E92M3
Happen to me too at jb4 map7.
08-22-2011, 07:00 AM | #6 |
2007 335i E92
44
Rep 624
not really sure.. should the threads not be that dirty after 30k ? perhaps it was not screwed in tightly enough ?
08-22-2011, 10:00 AM | #7 |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
Sometimes during oil changes oil will drip on the coilpak and make it's way down...
08-24-2011, 11:35 PM | #9 |
2007 335i E92
44
Rep 624
hmm.. got a misfire on #1 today.. guess it's the coil then.. picking up a new one tomorrow..
08-25-2011, 07:09 AM | #10 |
Rep 462
does the jb4 read afr from cylinder 1 cause i find it funny when i had my misfire in one there procede afr gauge would read zero when the dme shut the cylinder down that made it easy to fiqure out what cylinder it was with out pulling out the laptop
08-26-2011, 09:34 AM | #11 |
Joint Chiefs of Staff
4927
Rep 116,037
A Plug change is a good idea, and I usually recommend changing them every 20-25K when tuned. Its great preventative maintenance and if you DIY its pretty cheap
Mike |
