Turner Motorsports 335i boost gauge.
08-23-2011, 06:07 PM | #1 |
Rep 249
Is anyone out there sporting the turner motorsports boost gauge? Considering getting it before the tune but I dont know how it would look with navigation right above it.
08-23-2011, 10:18 PM | #2 |
Rep 1,465
Go get the ETS one. Same gauge and 1/2 the price. I just installed it in my 09 E90 this weekend. Only problem was with 03/09 Production is BMW removed the cigarette lighter/ashtray so the gauge always stay lit as if the lights where turned on. Other then that; not bad at all and a nice mod.
11 E92 M3 DCT Jerez Black ZCP...Eisenmann, Dinan, Fabspeed, IND, LUX
08-24-2011, 12:36 AM | #4 |
Rep 3,456
Drives: Harrop E90 M3
But they show a calculated boost reading. psi vs psig- run a V5 @ high altitudes and compare it to a known good gauge....your readings will jot match. Just as an FYI
08-24-2011, 12:38 AM | #5 |
3442
Rep 79,211
08-24-2011, 03:58 AM | #6 |
Rep 2,563
Get the new Rixster boost gauge with CANbus access. It doesn't come more refined and stock-like than that.
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
08-24-2011, 07:38 AM | #7 | |
Rep 2,898
Neil |
08-24-2011, 08:42 AM | #9 |
Rep 6,773
Best gauge on the market IMO is the p3 cars v2..super clean OEM look.
Reads Boost, Air temp, Coolant Temp, Battery V, EGT, 0-60 times, Shift Light AND it reads and clears codes.. To read boost accurately you have to tap the vacuum line..no getting around that. http://www.e90post.com/forums/showthread.php?t=466515 |
08-24-2011, 10:09 AM | #10 |
Rep 339
Drives: 07 e90 335i
Wife has one...its nice and works well. Easy to install.
08-24-2011, 10:38 AM | #11 |
Rep 2,221
Hey OP, I have installed a few of these. If you are set on it then the install is not too bad. Most difficult thing for a first timer is drilling the hole in the correct position right behinf the gauge as well as getting the assembly back together and having it sit correctly. After that the wiring is easy. Let me know if you have any other questions!
08-24-2011, 12:30 PM | #13 |
Mad Linux Guru On The Loose
1131
Rep 5,404
BOOM! Bingo!
08-24-2011, 12:32 PM | #14 |
1131
Rep 5,404
Sorry but I believe you are misinformed. You run the boost line anyway to get true accurate boost pressure in the manifold. You can also hook up two extra 5v input signals to the boost gauge.
08-24-2011, 07:40 PM | #15 |
Rep 2,875
Ya, I thought the Rixster V2 boost gauge reads boost through CANbus via the OBDII port?
The V1 boost gauge reads off the manifold/CP because you HAVE to tap into the vacuum hose.......no?
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
08-24-2011, 07:44 PM | #16 |
Rep 6,773
The v2 reads boost measure at the manifold by tapping the vacuum tee as well..this is the only way to measure boost accurately..its an analog reading..the rest of the gauge reads through the OBDII - digital
08-24-2011, 08:39 PM | #17 | |
Rep 2,875
I saw them demonstrating that the V2 (digital) gauge reads off CANbus, and the V1 (also digital) does not.....
08-25-2011, 12:28 AM | #18 |
Rep 6,773
YES,,I am talking about the "new" v2 gauge..I have it..and as I said boost is an analog read through the vacuum line..and the rest of the gauge reads digital thru CANbus
08-25-2011, 07:12 AM | #19 |
1131
Rep 5,404
+1. Same here. V2 digital gauge. Comes with a pressure sensor and a vacuum line kit. You tap the Y-spitter of the DVs to get true manifold pressure.
