DTC blincking over small bumps
09-15-2011, 11:24 AM | #1 |
Rep 275
Started happening for the past 3 weeks or so.
No codes. 40K on the clock. 18in rimns. Tire pressure set at 45lbs all around. Worn suspenssion? bushings? TIA Lou. |
09-15-2011, 11:34 AM | #3 |
Rep 288
This happened to me a few times recently.
It has stopped after I discovered that the negative battery terminal was loose. But I'm not sure if the loose battery terminal is the reason this is not happening anymore. |
09-15-2011, 11:55 AM | #4 |
Rep 5,627
09-15-2011, 12:01 PM | #5 |
Rep 17,879
This happens to me everyday in my parking garage. I park on the 5th floor and theres a small gap in the floor covered by an inch metal frame that the cars drive over. It flashes DTC every single time I go over it and Im only going 5mph. Im like SERIOUSLY????
09-15-2011, 12:25 PM | #7 |
atlien
15
Rep 371
Drives: '11 e90 335i
happens to me once in a while when i go over this railroad crossing near my neighborhood, if i am accelerating over it then it happens with greater frequency
09-15-2011, 12:43 PM | #9 |
Rep 275
09-15-2011, 12:56 PM | #10 | |
Rep 5,627
If you don't like the ride and handling with 33/41, then perhaps you might experiment with a compromise like 36/41. Tom |
09-15-2011, 01:22 PM | #11 |
Rep 7,089
Drives: '06 AW 330xi
My car is suppose to be at 32psi front and 36psi rear.
45psi is really high. Isn't that just below the max pressure rating on most tires? |
09-15-2011, 01:42 PM | #12 |
Rep 224
All this means is that the rear tires slipped a little going over a bump. Anything that would reduce traction will cause it to slip, such as too much air in tires, tires that are worn, going over metal or other slick surfaces. Going over a bump unloads the back end of the car which causes reduced traction. Any of the variables above will amplify the loss of traction. In the end there is absolutely nothing to worry about. The DTC is doing it's job.
11 BMW E93 M3-- 06 BMW Z4M Roadster
99 BMW M Coupe -- 85 BMW M635CSI 97 M3 Coupe (Track)--95 BMW M3 Coupe 91 BMW 850i 6MT--20 Ram 1500 16 Chevy Tahoe 4WD |
09-24-2011, 06:59 PM | #14 |
Rep 275
