BIMMERPOST Universal Forums Off-Topic Discussions Board Photography/Videography Wideangle
      09-20-2011, 02:14 PM   #1
panicos81
panicos81's Avatar
Cyprus
237
Drives: a white bmw
2010 BMW E92  [8.54]
2007 e90  [0.00]
Wideangle
Hey guys, need assistance (again)
Camera used, Nikon d5100
i need a wide angle lens mostly for landscape and urban pictures. i limited my options down to three lenses
Nikon 10-24mm f3.5-4.5
Tokina 11-16 f2.8
sigma 8-16mm f4.5-5.6
Things to take into consideration, i will most probably use the lower mm 10,11 or 8 respectively. i care about sharpness, colors, distortion. dont care about flares or vignetting (although it would be better without either).
Please also dont take price into consideration unless the performance is equal.
Thank you in advance,
P.S 1. Rodi please chime in since you seem to be the expert on Nikon..
P.S 2. other lens is a 35mm F1.8, dont need a big zoom lens though.
      09-20-2011, 02:17 PM   #2
khaye1
khaye1's Avatar
Philippines
161
Drives: 24 G87
  [10.00]
Tokina gets my vote...the speed alone on that lens will trump any lens for the money
edit: and 11 is plenty wide for a crop body.....aaaaah sorry, forgot about Nikon AF
      09-20-2011, 02:50 PM   #3
mr_milo
mr_milo's Avatar
Drives: 2011 E93 328i
+1 Here.
I have the Tokina 11-16 and using it with my D90. It's a great lens which is capable of some very low light shots.
Edit: Oops, I just realized you want to use it with a D5100. I don't think the D5100 has a focus motor on it. If that's true then you won't have autofocus with the Tokina. It needs a screw drive to focus. (Or you can manually focus)
      09-20-2011, 03:39 PM   #4
flyingfortress
Drives: 2010 135i
i just went through this whole thing on the same body and same subject matter (although dark photography is a big part of what i do)...
i ended up with a sigma 10-20mm. i know there are quality control issues with them, but i was able to try three and pick the best one. and it's sharp as i can image an wide gets - very comparable to the kit lens (18-55) in terms of sharpness/color.
my first choice after doing the research was the tokina 12-24mm but i wasn't able to try one first and wasn't comfortable ordering online without trying it.
i tried the 10-24mm nikon and wasn't impressed with the cost over the others. i thought it was worse than the sigma i ended up with in terms of sharpness.
the sigma 8-16 was very sharp and i liked it, i just didn't want to go with it since i do use the 20mm side of things.
apparently the tokina 11-16 is the end all be all right above the nikon 12-24, but it wont focus on our cameras automatically. a lot of people said that doesn't matter much with wide angles, but it still was an issue for me.
hope that helps? i know it doesn't. i read 20,000 reviews on each lens and was still completely lost. take your body to a camera shop with a card in it and try any lens you can, then go home and look at them on your computer. good luck!
      09-20-2011, 05:08 PM   #5
panicos81
panicos81's Avatar
Cyprus
237
Drives: a white bmw
2010 BMW E92  [8.54]
2007 e90  [0.00]
thanks man, i've been reading reviews for the past three days and still cant make up my mind. manual focus is not a problem.. i use manual focus eve when autofocus is available so no problem..
how was the 8-16? i like the idea of 8mm but my main concern is the bad reviews other sigma lenses have..
i cant try any of them on my camera, no shops have them in Cyprus so my purchase would have to be online and pray for the best!!
      09-20-2011, 08:26 PM   #6
1013mm
aka 1013MM
1013mm's Avatar
Hong Kong
1339
Drives: pokingly flush
2009 135i  [8.26]
Tokina 11-16 f2.8 would be my choice. I almost jumped on it. I als heard that that the 8-16 is great!
      09-20-2011, 09:04 PM   #7
The1
Drives: white 135
auto-focus or not, F2.8 from 11-16 is handy. lets say you shoot 100 pictures all at varrying focal lengths, and you shoot them all at 2.8 or 3.2. when it comes to the post processing, you're not going to have to adjust your exposures as much as if you had a lens that didn't have a consistent F stop.
I find this a huge benefit, even if i don't shoot wide open very often< i just know that it's not going to change on me when i'm concentrating on something else and want a little more zoom.
Constant aperture openings will always win for me.
that being said, I'm on a Canon, so you can discount my opinion. But the same characteristics carry over to all companies when it comes to this subject.
      09-20-2011, 09:43 PM   #8
scollins
Bootleggin' 'n Gunrunnin'
scollins's Avatar
150
Drives: 2024 X3 M40i
Nikon 14-24 and done.......
Budget-buster more than likely though.....
I like constant aperture zooms, so if I was looking at a more limited budget, I'd probably look at the 12-24 f4: http://bythom.com/1224lens.htm
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles
2019 Ford F450 STX, Oxford White
2013 Ducati Multistrada Touring S, Red
      09-20-2011, 10:29 PM   #9
skinrock
Agent Smith
skinrock's Avatar
280
Drives: 2016 i8
2016 BMW i8  [10.00]
Except that's an FX lens, which would effectively be 21mm on his body.
edit: I always get that mixed up, the DX lens would still be be affected by the crop factor. I always think DX lenses on a DX body are rated for the FX equivalent.
The i8 needs a V8 amirite?
      09-20-2011, 10:34 PM   #10
scollins
scollins's Avatar
150
Psssshhhhh, details details.
But even a 12mm DX lens will be an 18mm equivalent.
Scott
      09-20-2011, 10:35 PM   #11
skinrock
Agent Smith
skinrock's Avatar
280
Drives: 2016 i8
2016 BMW i8  [10.00]
Yea, I just edited my post. Always throws me off. DX is more about the size and cost, because DX on an FX body is too small for the sensor.
      09-20-2011, 10:47 PM   #12
rodi
192
Drives: your FACE!
i would say the tokina 11-16? if it was me, i'd grab the 14mm f/2.8 - it would be a better investment, long term.
how wide do you really need to be? might as well get the rokinon 8mm and just straighten it in post. ?
2009 135i | space grey | sport | navi | hifi | heated
dinan stage 2 software | bmw performance exhaust
kw v2 | hotchkis front sway | vmr v710
      09-21-2011, 01:16 AM   #13
panicos81
panicos81's Avatar
Cyprus
237
Drives: a white bmw
2010 BMW E92  [8.54]
2007 e90  [0.00]
thank you all for your comments,
the Nikon 14-24 f2.8 would be great but the price is too much. i said the price doesnt matter for the three above, this one at $1600 used is a bit too much.
rodi i have considered the rokinon 8mm and then straighten it but the procedure its kind of difficult and the results not gret, you have to crop some part of the pic i think so no good. i´m considering this lens for the fisheye effect though as it is inexpensive a has great reviews.
      09-21-2011, 02:13 AM   #14
TL
TL's Avatar
Drives: Happy on H&R coil overs
2008 335xi  [1.00]
For DX body I went with the Tokina 11-16mm. It's comparable to the Nikon 14-24 but at half the cost.
      09-21-2011, 08:25 AM   #15
Jon D
Jon D's Avatar
Scotland
249
Drives: 2022 840d
Sigma 8-16 for me, good review here: http://www.fredmiranda.com/reviews/s...&cat=37&page=3
      09-21-2011, 08:29 AM   #16
Chewy734
Drives: 2006 BMW 330i ZPP, ZSP
even though I'm not a Nikon owner, I have friends who are. I would listen to rodi and Tim's suggestions.
      09-22-2011, 02:44 AM   #17
panicos81
panicos81's Avatar
Cyprus
237
Drives: a white bmw
2010 BMW E92  [8.54]
2007 e90  [0.00]
thank you all for your suggestions,
decision made, i will stick with mt 35mm f1.8 for know, learn the camera a bit since its new, save up, and santa will bring me a Nikon 14-24 f2,8
      09-22-2011, 04:10 AM   #18
mr_milo
mr_milo's Avatar
That's probably a good move! I bought the Tokina 11-16 but found it's a special use type of lens. I use my 18-200mm much more often and am now looking for either a 35mm f1.8 or a 50mm f1.8 for low light but I can't quite decide.
Enjoy!
      09-22-2011, 04:19 AM   #19
panicos81
panicos81's Avatar
Cyprus
237
Drives: a white bmw
2010 BMW E92  [8.54]
2007 e90  [0.00]
Enjoy!
very happy with my 35mm f1.8.. sharp, fast. i only have it for a week though so still exploring it.
      09-22-2011, 10:24 PM   #20
Inspired
Inspired's Avatar
156
Drives: 335i
That is no where close to Wide angle. I have one and I only use it for low light situation.
I have the 12-24MM. But I am planning to sell it for a 24-70 and upgrade to a FX.
Here are some pics I got..
      09-23-2011, 01:45 PM   #21
scollins
scollins's Avatar
150
Yikes, that is some distortion on the right side! That lamp post looks crazy!
Scott
      09-23-2011, 03:05 PM   #22
dryicerx
Drives: 335is
I have the sigma 8-16mm and it's scary wide and pretty sharp as well when stopped down a notch. In the wide end, even 1mm makes a huge difference, so that was my reasoning for going with that instead of the other ultra wides. My only complaint is the aperture which I think is a bit too limited, but then again that's asking for too much at that focal length and pricepoint.
http://www.e90post.com/forums/showthread.php?t=451984 has a video and photos I made with the Sigma 8-16mm lens (the front element and overall lens survived countless bugs splatters, slight rain and moisture like a champ... even though it wasn't made for that).
