New COBB user data logging fun
10-05-2011, 12:06 AM | #1 |
Rep 205
Hi all,
Just got my AP in the mail and it's my first mod to the 335! Been having a lot of fun with the increased power, just wanted to post up some graphs and ask a few questions. First, a rolling start from ~20mph in second gear through 2nd and most of 3rd: Any idea why it doesn't appear to make boost until ~3200rpm's? I'm surprised it takes that long to get to a state of positive pressure. Second, can anyone confirm if the COBB tune starts to pull back boost at ~6000, so the dip in boost from 6-7K RPM is expected? Actually looks like it's pulling the boost starting at about 5800rpms... Other than that, it appears to hold the boost pretty stable for the time I was in 3rd gear. Then I just happen to be playing around on a night where we actually got some rain in Arizona, so temps were good and the ground was wet! Here is a graph of some tire spinning at slow speeds (quick take off from stop lights, flooring it coming out of a turn, etc.): Again it surprises me a bit that for most of this, I'm not actually boosting! For very few parts of that graph does the pressure actually become positive. Maybe I'm misunderstanding how to read it, but my assumption is that negative values indicate a vacuum exists in the intake manifold, while positive numbers mean there is negative vacuum (or boosting). Anyways, all in all a pretty good experience with Cobb so far! Some times I'm a little uneasy about running it as it seems like the engine falls on its face occasionally, but I'm not seeing much ignition correction so I'm not sure what's causing that. Maybe what I'm feeling is the affect of DTC kicking in? Not sure... |
10-05-2011, 12:34 AM | #3 |
Rep 7,377
when you log you should ALWAYS disable all nannies to prevent intervention. best is to roll in 3rd and shift to 4th .
10-05-2011, 09:48 AM | #4 |
Rep 205
10-05-2011, 02:46 PM | #6 | |
Rep 205
I modified the default data log options a little, but in general I have requested / actual load, rpm, boost, boost delta, wastegate duty cycle for bank1 and bank2, and the ignition correction for all cylinders. Generally the ignition correction is typically 0's, at least during full load. Occasionally it pulls up to 3-5* of timing under easy acceleration around 1500-2500rpms, kind of odd. Maybe i'll switch to the actual timing advance for each cylinder so I can graph that and see if there are any dips. What parameters do you recommend? |
10-05-2011, 03:07 PM | #7 |
Rep 1,760
the 2nd graph looks like the graph is not adjusting properly to accurately display boost pressure.
That said, over 5000rpm, the boost pressure is somewhat inaccurate on the cobb AP datalogs it seems. And yes, it's normal for boost to drop as you get closer to redline. |
10-05-2011, 03:42 PM | #9 |
Rep 205
Not too sure yet.. I was a bit concerned about that cause I know AZ has bad gas, not to mention most stations don't even carry anything above 91.
That being said, occasionally when pressing the pedal and getting into boost it feels like there is some hesitation, not sure yet what the cause of this is. Looking at requested load vs actual load, they are typically pretty close. Also I don't notice any timing being pulled when under full throttle conditions up to ~14psi. But as I stated earlier, let me try logging the actua lignition timing instead of just the correction fields and see where we're at. |
10-05-2011, 03:46 PM | #10 | |
Rep 549
Usually I don't graph the logs, since you can just read them straight away in Excel and understand what's going on. |
10-05-2011, 04:29 PM | #11 | |
Rep 205
10-05-2011, 04:36 PM | #12 |
3442
Rep 79,211
10-06-2011, 01:55 AM | #13 | |
Rep 549
Running Cobb stage 1 aggressive with 94 octane. |
10-06-2011, 06:16 AM | #14 |
Rep 7,377
you should go FBO and run stage 2+
10-06-2011, 08:11 AM | #15 |
Rep 205
Thanks for checking and getting back to me! Guess I may have a problem to chase down as these timing pulls on low loads are actually pretty consistent on each log I've taken.
10-06-2011, 08:28 AM | #16 |
Rep 549
Will do that early next spring if I still have the car...recently she has been running strong without problems so I don't have any plans on starting a new affair
Wintertires spins all over, but next spring...I'll hide out in the garage for a day or two... |
10-06-2011, 08:30 AM | #17 | |
Rep 549
As for me looking at my logs, glad I can help out in some way. |
