E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > crazy electrical mystery - need some advice
Reply
      10-07-2011, 11:39 AM   #1
jpsimon
Team Zissou
jpsimon's Avatar
Drives: 2022 AWD M3 Comp - SMB
/update/ $2300!!!!!!!! Wire going from battery to the front of the car is failing (melting/discolored behind glove box)... they have to order the part from germany and say it's a 16 hour job. fuck me!!!!!
/update 2/ the SA called back to tell me she jumped the gun on that news. What she meant to say is that is what he'll be checking next... and that is the potential cost.... thanks for scaring me!
/ update 3 /
SA called, they do need to order that cable but labor will only be half what they thought. so ~$940 total instead of $2300.... that's sort of good news at least.
there is some code being thrown about "map overheating". I'm only relaying info from the SA, so she might be mistaken. But she also said the DME might have an issue and need replacing - but it might be covered under some emissions warranty.
On the way home from work yesterday some strange things happened. It was as if the connection to the battery skipped a beat a few times over the course of the drive. My V1 turned on and off when this happened, i got the "AWD/DTC DISABLED" warning on the iDrive and the time reverted back to "--:--". There were never any hiccups in terms of drivability, only the electrical systems.
I had to stop at a buddy's house to pick something up. Pulled in to the driveway and waited for him to come outside. I went to shut off the car by pressing the start/stop button and as I pressed the button the car just died - as if there was no battery in the trunk. Electrical shut off engine shut off... Key was stuck in the fob-vagina and wouldn't come out. Completely dead.
With the key stuck in the fob-vag i removed the physical key so I could get in to the trunk to check the battery. Walked around back... put the real key in the trunk and twisted and................
BOOM!!! all lights on, car turns back on, everything is fine. I check battery, connections are all sound... Drove home no issues. Check the car this morning, car turns on fine.
WHAT THE FUCK?!?
      10-07-2011, 11:42 AM   #2
Brey335i
Drives: e46 ///M3
My car behaved strange in a very similar manner for about a week on and off before one night my battery just completely died on me.
It could either be the charger cable to the battery is going bad or the battery itself
      10-07-2011, 12:17 PM   #3
import36
Burrito bowl connoisseur
import36's Avatar
Drives: 2015 Nissan GTR Black Edition
jp is that still the stock battery...or did you ever get a lightweight one? just curious how old the battery is...
      10-07-2011, 12:19 PM   #4
EastBayE90
Formerly (-(ellblazer420
EastBayE90's Avatar
Drives: 07 E90 335i M/T, 15 F80 M3 DCT
fob-vag that is so funny. Was it raining at all or weird weather that could have caused a possible leak? Then maybe water was creating the weird electrical issue? As it dried you no longer had the problem?
(410whp 445ft/lbs | DCI + Meth Only)
OpenFlash OTS Stage 1 Flash | Vishnu PWM Meth Kit | Vishnu DCI| Forge DVs
      10-07-2011, 12:25 PM   #5
xclone
Putting more gas in the car...
Drives: 2008 535i
Have you checked the trunk for water? Check in the spare tire well and the electrical wells. If you have a clogged sunroof drain then you could have water leaking into those areas and doing some major damage.
2008 BMW 535iA | Cobb Stg2+ | Injen Intake | AR Catted DP's | CP-E FMIC | Turbosmart DV's | ER Charge Pipe
      10-07-2011, 12:29 PM   #6
jpsimon
Team Zissou
jpsimon's Avatar
Everything seems dry... I just replicated the issue and solution to a T
Started up the car fine, drove somewhere... drove back... Pressed the start button to turn off car - and it died with the key stuck. Take out escape-pod key, put it in the trunk and twisted. as soon as the trunk opened the electricity went back on
same exact experience as last time
      10-07-2011, 12:36 PM   #7
Brey335i
Drives: e46 ///M3
I have no idea why the trunk would return the power... this is gonna require an electrician's input. Don't we have any of those?
      10-07-2011, 12:40 PM   #8
Ilma
Drives: 2008 135i
Well the real problem is sticking your fob into someone's vagina instead of the dash.
But seriously...that was a very funny analogy.
I know that does't help you solve your problem, but it lightened my day.
So thanks Jonah!
Maybe the speculation of a low battery is correct. I have heard of flaky things starting to happen when voltage gets marginal on this platform.
      10-07-2011, 12:48 PM   #9
JO3
Drives: a lot
There's been other thread on here about people's cars going crazy before their battery died. If you battery is 4 years old or so or older, then it's probably time for a new battery.
      10-07-2011, 12:51 PM   #10
jpsimon
Team Zissou
jpsimon's Avatar
Going to the dealer around 3, luckily they had some loaners.
Also they're going to do my HPFP and Injector recalls - cool.
      10-07-2011, 12:51 PM   #11
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
It sounds like your ECU is going to sleep. Then when you open the trunk it wakes up.
Hmm.... If your battery is older then 3 years it might be that. Otherwise I would pull the tune to see if that is interfering in some odd ball way.
If it does it without the tune then you might need to go to dealer.....they will likely blame it on the battery if its old though.
      10-07-2011, 12:53 PM   #12
jpsimon
Team Zissou
jpsimon's Avatar
My car is a 2008, on the original battery - safe to assume it's that (even though a shop just recently checked to make sure the battery was still good).
      10-07-2011, 12:55 PM   #13
This car is quite sensitive to voltage/load swings. I do know that.
      10-07-2011, 12:55 PM   #14
e90328i
Drives: 07 E90 335i
your battery is going, had the same symptoms on my old 328i and didnt think much of it till it wouldnt start after work and was stranded. Replaced battery under warranty and everything was good.
      10-07-2011, 01:54 PM   #15
cwn23
Drives: E92
Had the same thing happen to me...Check all the connections on the battery terminal including the ones near the red connections...Mine turned out to be a loose bolt to the positive terminal...I guess all the times i loosened up the bolt and I guess I didn't tighten it enough. Well after tightening the nut I have never seen another DSC malfunction or experienced the car having no electric after pressing the on/off button..
Happened to me a couple of times before I finallly found the problem. One time I did the same as you and took the key out of the fob and then went to open the trunk. I guess opening the trunk must have shook the terminal enough to make connection again...
      10-07-2011, 03:29 PM   #16
jpsimon
Team Zissou
jpsimon's Avatar
there might be a silver lining in all this - back in the day i payed out of pocket to have the dealer replace 3 injectors ($1000). now my car is under the injector warranty, so they said i might be able to get my money back
      10-07-2011, 03:50 PM   #17
pentaxis
pentaxis's Avatar
Drives: Space Grey E92 335i
That would be a stroke of good luck! Hope ya get it!
      10-07-2011, 06:16 PM   #18
danniexi
danniexi's Avatar
Drives: 2022 F97 X3M Comp LCI
had the same thing happen to me a while back. I was at the car wash, the car was on (not engine, just electronics) and everything shut off on me. I had to go to the back and physically open the trunk. The thing turned on by itself. I almost shat my pants thinking water had gone in, but everything was dry. Since then I never had the problem.
Weird. Guess I'll get that battery replaced soon.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE
BMW MY08 E92 335XI - GONE
BMW MY06 E46 325XI - GONE
      10-11-2011, 02:35 PM   #19
jpsimon
Team Zissou
jpsimon's Avatar
So here's a small update, please feel free to shoot me some more ideas:
They've checked the battery and alternator and both are fine.
Could a loose connection in the ECU compartment cause this sort of issue? That being said - I assume they already looked in there and found no issues because they asked me about the "ecu box i installed". (that question was just in relation to when they needed to install new software, they didn't want to "ruin" it).
      10-11-2011, 03:18 PM   #20
jpsimon
Team Zissou
jpsimon's Avatar
FUCK ME IN THE GOAT ASS!!!!!!!
Apparently the wire from the battery up to the the front of the car is melting.... $2300!!!!!!!!!!!!!!
on the brighter side - if you even want to call it that, she said ill most likely be getting $1000 back from when i payed out of pocket for the injectors (which my car is now under the recall of).
fuck me!!
      10-11-2011, 03:23 PM   #21
joec500
Drives: it has 4 wheels
How the hell did it start melting??? and $2,300 dollars!!!!! Is it part of some more expensive harness?? Here is one disadvantage of a trunk mounted battery.
      10-11-2011, 03:24 PM   #22
jpsimon
Team Zissou
jpsimon's Avatar
they said it's melting/discolored behind the glove box
Reply
e90post
