ABS, DSC Brake lights and 5D90????
10-09-2011, 12:52 PM | #1 |
Rep 377
Having issues with my ABS, DSC and Brake lights illuminating in yellow after emoving the lowering springs. Ran the BT and came up with an array of codes pertaining to the DSC:
5D93 5DE1 5DE0 5D96 5D90 I cleared all the codes but 5D90 keeps coming back and the lights won't go away. The flash out momentarily upon clearing but come right back. I tried resetting the steering angle sensor, checked all the wheel speed sensors, got an alignment, checked the related fuses but still can't figure it out. Can anybody help me?
07 e92 335i Best run: 11.83@ 120.4 w/ 1.84 60' and 2127 DA
10-09-2011, 01:05 PM | #2 |
Rep 4,764
Wish I knew. Hopefully someone will be able to help out. Hopefully it is not the DSC module.
10-09-2011, 01:07 PM | #3 | |
Rep 2,875
How did you reset the steering angle sensor? With what tool? Just curious because I'd like to check to see if my steering angle sensor is off...
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
10-09-2011, 02:11 PM | #6 |
Rep 377
What codes did you throw? Was it just the 5D90 or others too?
10-09-2011, 02:27 PM | #7 |
Rep 377
Blinkers still automatically go off after a turn so it's no the steering sensor
10-11-2011, 09:09 AM | #10 | |
Rep 708
I hope that is not the case for you, but if it is you should be ready to take out your wallet... unless you still have warranty. |
10-11-2011, 09:17 AM | #11 |
Rep 462
yeah trevor those where the same codes i received but make sure its the what it is doing the other tests as my cruise control still worked but my autoleveling did not
10-11-2011, 09:26 AM | #12 | ||
Rep 377
10-11-2011, 10:40 AM | #13 | |
Rep 708
10-11-2011, 03:26 PM | #14 | |
Rep 377
I saw that part you are talking about in the drawing on real oem yesterday and you may be right. The funny thing is that I did a search with that part number and it came back as a rear diff mounted speed sensor for the 335 as well as a few other BMW's but I confirmed today from a few sources that the 335 does not have a rear diff mounted sensor. The pain is that the part we are talking about it mounted underneath the abs/dsc pump and control unit and the only way to get to it is to remove that stuff and to do that the brakes need to be drained first. I might have a tech look at it and run the cdes to see what he thinks before I buy anything. Depends on how much he wants to charge me and how sure he will be about knowing what it is.
10-12-2011, 03:11 PM | #15 |
Rep 708
That's prob your best bet... Pay the $120 or whatever your dealers diag fee is and get a better idea of what the problem is.
10-12-2011, 10:44 PM | #17 |
Rep 868
I had the same lights.... Brake dct and abs
Blinkers worked but no cruise or light leveling At dealer now and it's covered by cpo plus I had a tranny leak ..... Unrelated
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets, Ebay 4" chrome Tips, Lux Angel Eyes **********11.910 @ 117.09***1.851 60'********** |
10-13-2011, 08:22 AM | #18 |
Rep 708
10-14-2011, 03:58 PM | #19 |
Rep 377
Waiting on a couple of wheel sensors I ordered to plug in and see if they rectify the situation or not. A local board member looked for the 5D90 in a database he has access to and didn't find it. If the wheel sensors don't help then I will have a BMW tech look at it and run the codes.
My cruise control isn't working at this point but I have no codes for anything other than wheel sensor related stuff at this point.
10-16-2011, 10:00 AM | #20 |
Rep 28
What was the diagnosis from the dealer? I have all of three lights on with no cruise control but my light leveling works.
10-16-2011, 10:32 AM | #21 |
Rep 377
There are a bunch of reasons that cause the same lights to go on. The info you need is on the codes being thrown. Most of the systems are tied together too. You have the exact sypmtoms I do at this point but it could be something completely different. You won't know until you read the codes. Post the up here when you find out
10-18-2011, 01:09 PM | #22 |
Rep 377
5D90 and 5D96 were caused by a faulty front driver side wheel sensor. I bought the parts fron ECS Tuning(front wheel speed sensor and plastic fitting that it plugs in to) and installed them in a matter of 10 mintues. Drove the car 100 yards and the codes/lights went away. All is back to normal.
