Stage 2 Sport -- Need Help
10-11-2011, 11:31 PM | #1 |
Rep 2,626
Hi everyone,
I've installed Stage 2 Sport this weekend, but I don't feel the extra power! The logs seem to prove that. Moreover logging showed 2 more worrying issues that I would like to know everyone's take on. BTW I'm sure I have stage 2 installed (double checked, and AP shows that, and 29f4/5 codes are masked). Looking at the data, peak boost was 13.25 PSI. Other issues that worry me: 1) after 6000 rpm, Boost falls short of Requested boost. Does this mean my turbos are going south and can't hold boost? anyway to check? 2) Cylinder 5 timing shows a drop... what is the cause of this usually? could it be the spark plug?
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
10-11-2011, 11:42 PM | #2 |
Rep 6,631
Boost reporting past 5k RPM on the Cobb stage 2 beta maps is inaccurate. Disregard that.
Did you log only cylinders 1 and 5? Or did you log all six? Can you post a log of all six cylinders if available? A single drop in one cylinder isn't a big deal. When you see multiple cylinders drop timing at the same time that's when you have something to worry about.
E90 LCI N54 6AT
10-11-2011, 11:49 PM | #3 | |
Rep 2,626
Yes I did log all 6, I haven't posted those because all of the curves perfectly match (overlay) except Cylinder 5. What's your take on Stage 2 performance? Shouldn't see more boost? I mean it's exactly similar to stage 1 (from peak boost at least)
10-11-2011, 11:54 PM | #4 | |
Rep 6,631
But good, if you had a drop in only one cylinder, nothing to be worried about.
E90 LCI N54 6AT
10-11-2011, 11:56 PM | #5 |
Rep 2,626
Good to hear, thanks for your input!
10-12-2011, 05:45 AM | #6 |
Rep 395
yeah but OP is still only seeing 13psi boost at low to mid rpms on stage 2? Is that normal?
COBB S2+ - Mr.5 CAI, Catless DP, Catless MP, AMS FMIC. |
10-12-2011, 05:52 AM | #7 |
Rep 7,377
seems you have throttle closure between 2800 - 3800 , that might explain the low boost on low rpm .
10-12-2011, 06:06 AM | #8 |
Rep 395
Yes but if you look at his req.boost its never over 13!!
10-12-2011, 09:05 AM | #9 |
Rep 6,631
Guys if he had a boost leak his wgdc wouldn't be at 30%. It's a boost reporting issue. When we stage2+ guys report 18 psi, it's below 5k rpm.
If the op wants a second opinion, email Cobb. There is nothing wrong with that log.
E90 LCI N54 6AT
10-12-2011, 09:39 AM | #10 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
Full uninstall, refresh of software on AP and reinstall.
10-12-2011, 10:42 AM | #11 |
Rep 2,626
I wish I had another log of stage 2 sport to compare with, all logs are for stage 2+
I guess I'm going to email COBB. and mithiral67's idea is not bad either, I should give it a try
10-12-2011, 10:43 AM | #12 |
Rep 2,626
May be COBB can dial in here
10-12-2011, 11:12 AM | #13 |
Mad Linux Guru On The Loose
1131
Rep 5,404
+1000
Cobb says that's not needed but experience taught me differently.
10-12-2011, 04:06 PM | #14 |
Rep 2,626
Alright then i'll do it today. Thanks!
10-12-2011, 05:25 PM | #15 | |
Rep 468
Cheers, Rob |
10-12-2011, 05:31 PM | #16 | |
Rep 2,626
Thanks!
