meth failsafe for flashed cars
10-12-2011, 11:41 AM | #1 |
Rep 575
I know everyone is stressing about failsafe when it comes to a flash tune, and on the forums vendors push their own systems that are compatible with their piggyback systems, mean while many other comunities use meth, so how are we any different ?
So far as I understand most use failsafe modules by connecting the 12v wire to the waste gate solenoid. The loss of flow will send a 12v signal to the solenoid and it takes 12v for the wastegate to open, and an open solenoid will cuase the boost to drop. Last edited by PlutoniumTans; 10-12-2011 at 03:51 PM.. |
10-12-2011, 11:44 AM | #3 |
Rep 575
10-12-2011, 05:41 PM | #5 |
Rep 1,719
10-12-2011, 05:47 PM | #6 |
Rep 1,142
If its not broke why fix it! The way the failsafes are working with Procede and JB4 are pretty much fool proof, why change it and go another direction. I am sure once Cobb integrates meth into their maps this solution.
10-12-2011, 05:53 PM | #7 |
Rep 838
What meth kit and flash do you have?
Austin @GIAC suggested that the ECU takes over when the knock sensor and dials back boost when in an unsafe condition. |
10-12-2011, 05:57 PM | #8 |
My X5d tows my spec miata to the track.
74
Rep 1,254
Personally i view meth as an enhancement and not a requirement. You get into trouble when you NEED to run meth to keep your tune safe. If you've advanced the timing and leaned things down depending on a couple hundred dollars worth of tubing and failsafes to keep your 10K motor safe you better be doing it in an application that you can afford to lose. Run a safe tune that will benefit from cooling and increased octane and you'll get the benefits without the worry of problems WHEN things don't work properly.
10-12-2011, 06:03 PM | #9 | |
Reborn
87
Rep 1,217
10-12-2011, 06:09 PM | #10 |
Rep 6,773
10-12-2011, 06:33 PM | #11 |
Rep 1,719
10-12-2011, 06:40 PM | #12 | |
Rep 6,773
The failsafe is what concerns me..and pump map has been plenty so far..so havent explored meth..but still curious. |
10-12-2011, 06:47 PM | #13 |
Rep 128
10-12-2011, 06:49 PM | #14 |
Rep 6,773
10-12-2011, 06:59 PM | #15 | |
Rep 128
Its a piggy. So it may be possible you heard some incorrect information. |
10-12-2011, 07:03 PM | #16 |
Rep 6,773
Maybe i wasnt clear but piggys are not an option...Im not interested in piggys..the thread is about failsafes for reflashes..but thx for the info
10-12-2011, 07:06 PM | #17 |
Rep 128
10-12-2011, 07:12 PM | #18 |
Rep 838
Huh...Are you saying that the piggy maps are switched upon lean/no flow detection all on by itself? The original question was if there is a flash with a failsafe map....so far I haven't found one. Besides, piggies are not as quick as as innate ECU program.
10-12-2011, 07:16 PM | #20 |
Rep 1,142
I think you have it backwards. With procede meth integration failsafe when there is enough flow the procede transitions to a more aggressive setup (map). When there is no flow or insufficient flow (blockage, leak) the procede never changes over to aggressive map and stays on the regular pump gas map and settings.
10-12-2011, 07:16 PM | #21 |
Rep 6,773
10-12-2011, 07:24 PM | #22 |
Rep 1,719
Sorry chap, I suspect I am the cause of the .
I was merely thinking out loud that there probably isn't a fail safe that can be integrated with a flash, simply due to the nature of the flash. Whereas a piggy has additional hardware that controls map switching based on meth flow. |
