Upgrading Turbos. opinions.
10-13-2011, 03:08 PM | #1 |
Rep 1,422
Sending my spare set of turbos to a indie shop to see what they can do. What would you have these guys do if they were doing your turbos? Only thing out of the ordinary I want is to keep them water cooled. Hopefully we can get a good quality upgrade that's also in the price realm of the average garage modder. Im not getting my hopes up but if this thing works out it will be a good thing.
10-13-2011, 03:24 PM | #2 |
Rep 3,730
Replace the 2 snails with 1 large hair dryer
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
10-13-2011, 05:30 PM | #4 |
Rep 1,571
For a compressor only upgrade all you have to do is machine the compressor housings, the centersections (to accept the bigger wheels), buy rebuild kits, clean, reassemble, and rebalance. Although the gains will be less significant and the Engines VE will essentially remain unchanged, you may still find this is for you as it'll be affordable. This is the typical offering as it's simplistic.
A caveat we have with used turbo cores is that the internal wastegates are often very worn, so you really don't want to sink more $$$ into housings that contain excessively worn internal wastegate components. So replacing those components becomes a concern, which comes at a cost. Buying new OEM complete turbo replacements may become the best option to overcome this. If you want to see more worthwhile gains, it's not going to happen with the tiny OEM turbines. So then you must charter into the full upgrade waters. In order to do the full upgrade (bigger turbines) you'll need to locate and adapt in new complete donor centersections. None you find will work with the OEM lines so then you will have to manufacture new lines or further enhance the new centersection to work with the OEM lines (where possible). The turbine housing will require substantial modifications to adapt to the new centersection, much beyond simply machining it to accept the bigger turbine. Tooling and machine time is considerable throughout the process as the manifolds are welded to the turbine housings. This is a watered down version but in the end what seems like should be a nice easy cheap project, turns out being a very expensive nightmare if you go the full mile. Simply put turning these things into anything significant will not come cheap nor easy. |
10-13-2011, 07:50 PM | #6 | |
Rep 1,422
10-13-2011, 08:29 PM | #7 |
Rep 1,571
10-13-2011, 09:49 PM | #8 |
Rep 2,197
Not to get too far off topic, but has anyone experience with the Helix upgraded turbos? Real information is kind of hard to come by, and with tax return season coming it's looking really tempting
10-14-2011, 09:57 AM | #9 |
Rep 3,730
+1,000
10-14-2011, 02:33 PM | #10 | |
Rep 2,428
I have a sneaking suspicion they are made by Tial...same as the EPL and eBay turbos. |
10-14-2011, 02:54 PM | #11 | |
Rep 300
When and if they ever have an N54 or N55 offerings, they won't be in Mitsubishi/MHI housings -Michael
DD: 2007 BMW 335i Sedan
Weekends: 2004 Porsche 911 C4S Last edited by Skydive; 10-14-2011 at 03:09 PM.. |
10-14-2011, 06:38 PM | #12 | |
Rep 2,428
When I say "sold", that means the first turbos JP bought, and maybe a handful after. I don't know who currently makes them, but Tial got a lot of warranty returns from them so they stopped producing them asap. Last edited by BrianMN; 10-14-2011 at 06:45 PM.. |
10-14-2011, 07:48 PM | #14 | |
Rep 300
My business partner and I had a company which sold several TiAL products. (In fact, that company and it's co-founder designed and remain the sole distributor of TiAL's range of products for the B5 Audi S4.) I am no longer involved with the company, however I remain a close friend. During the time of the EPL N54 turbos, our company was the single source wholesaler of those turbos to EPL. They were built by and purchased directly from a third company with which TiAL partners on some projects. (The N54 product was never a TiAL partnership.) TiAL was not involved in the product, nor were any TiAL components used, or represented as such. Our company processed all of the warranty units for EPL, and coordinated good faith with the manufacturer. (None of this had anything to do with TiAL beyond a completely unrelated business partnership between TiAL and the manufacturer.) Fact. -Michael
Weekends: 2004 Porsche 911 C4S Last edited by Skydive; 10-14-2011 at 07:59 PM.. |
10-14-2011, 07:50 PM | #15 |
Rep 232
I would like to see Billet Turbos....Billet seems to be the freshest thing out on the block making ridiculous top end and promoting quick spool
10-16-2011, 10:53 AM | #16 | |
Rep 1,283
Last edited by TurboBullett@Ambient Thermal Management; 10-16-2011 at 10:58 AM.. |
10-16-2011, 11:01 AM | #17 | |
Rep 2,197
10-16-2011, 11:07 AM | #18 | |
Rep 1,283
Last edited by TurboBullett@Ambient Thermal Management; 10-16-2011 at 11:54 AM.. |
10-16-2011, 12:40 PM | #21 |
Rep 2,197
