Help Me Read My Logs
10-14-2011, 06:28 AM | #1 |
Rep 2,590
First time really logging and I was wondering how these looked. Based on what I've picked up, it seems ign adv is extremely low in comparison to where it should be.
This is with the v5, 93 gas, ets ic, bms filters and about 55 degree temps. Edit: I feel stupid for not knowing how to add a log. It isn't the copy and paste function I guess. Last edited by pits200; 10-14-2011 at 07:27 AM.. |
10-14-2011, 06:33 AM | #2 |
Rep 7,377
nice log.
10-14-2011, 06:48 AM | #4 |
Rep 2,590
10-14-2011, 07:10 AM | #5 | |
Rep 7,377
you need to upload it as an attachment. Take a print screen of it , save it as image and upload it. GO Advanced and scroll down a little, you will se the attachment button.
10-14-2011, 07:28 AM | #6 |
Rep 2,590
10-14-2011, 07:34 AM | #7 |
Rep 7,377
map settings ? which map ?
Looks fine to me. Seems you had traction control on?
10-14-2011, 07:47 AM | #9 |
Rep 2,590
Map 1, max boost set to 14. I'm on the 7-29 maps.
Ya, traction control was on but this was a 3rd gear pull and no lose of traction. I thought the ignition advance was too low dipping down to 6.5 around 4500rpms. |
10-14-2011, 08:04 AM | #10 | |
Rep 7,377
If you have autotuning on put aggression to 1 , initial boost 30% IC50% and max boost 14 psi. drive around for a while and do some pulls than log 3rd and 4th gear couple of times.
