8.1sec 60-130mph, 7.0sec 100-200km/hr
10-16-2011, 11:24 PM | #1 |
Rep 5,876
Working my way down towards the 7s...got it down by 0.1sec from last best time...what change is changed the base COBB map from 11AFR to 12AFR , same meth 100% CM7 and CM10 nozzles, no lift shift...
Overview: ==== COBB stockish tune ("12" AFR, stock timing, stock boost) JB4 map6 + 50meth add (doesn't hold 20psi though, wish it did, 12ohm should solve it but its not in yet...at the moment this is 20psi down to 18psi for majority of the 4th gear pull except post shift, see previous JB4 datalogs) 100% meth CM10 + CM7 nozzle VMR VB3 19x8.5 rims front 245/30/19 Kosei K1 17x8.5 275/45/17 MT ET DRs rear pump 94 gas full weight (all seats in) ============== Here's the run, 8.12sec 60-130: And for the European guys, 7.02sec 100-200km/hr: |
10-16-2011, 11:51 PM | #5 |
Rep 5,876
10-16-2011, 11:53 PM | #6 |
Rep 1,708
Man, you really should try the procede in the piggyback setup... just set all the tables to stock except for boost... you could even add some advance. I bet you are kinda dying to try it. do it, come on... shiv may even send you one under the table hush hush. for me? i'm so curious to see if it works well.
10-16-2011, 11:54 PM | #7 | |
Rep 5,876
ATR is close to being released though |
10-16-2011, 11:58 PM | #8 |
Rep 1,708
10-17-2011, 12:02 AM | #9 | |
Rep 5,876
i want to see some high boost with added timing runs on the procede with RBs or stock turbos, not on my car though lol This has been out for a while, why is no one pushing it and bringing numbers to us using that setup? I really wonder how that added advance plays out over a bunch of high speed 60-130 pulls |
10-17-2011, 01:21 AM | #10 |
Rep 7,377
thats really impressive man ! congrats!
10-17-2011, 01:33 AM | #11 | |
1750
Rep 17,960
Drives: A Lot
I've been doing repeated 60-130 pulls on Hellblazer's DCI+PWM meth 6MT over the last few days. Only adding 1.5 deg of timing between 5-6k and it's running a consistent 10.5s passes. Again, this car is 99% stock with no weight reduction. Just DCI and PWM Meth/Procede running on 91oct. I have about 10 runs showing max, consistent timing all the way to 130+mph. So I, as well as just about all our Aggressive map beta testers who have been doing high speed pulls, would say that the advance plays out quite well. EDIT: Here's one high speed run (2nd->3rd->4th) on Hellblazer's 6MT, running meth on top of 91oct: And another one but with No-Lift-Shift enabled: Shiv Last edited by OpenFlash; 10-17-2011 at 01:45 AM.. |
10-17-2011, 01:33 AM | #12 | |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
1.3k: $73k
The i8 needs a V8 amirite?
10-17-2011, 02:11 AM | #13 |
Rep 2,563
Wow. Very impressive.
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
10-17-2011, 02:23 AM | #14 |
Rep 12
Very, very impressive
I installed COBB stg2+ yesterday and took a quick test run doing 8,7 sec 100-200 on 1:st try. (on COBB only, no meth/JB4) I´m very pleased with COBB so far, car drives like stock around town. Going to do some more testing with COBB only before adding boost/meth with JB4.
BMW 135i -08
AR DP, Berk full exhaust, RB turbos, COBB AP/JB4, CMGS, AMS FMIC, STETT CP My car: http://www.garaget.org/?car=169403 |
10-17-2011, 02:26 AM | #15 | |
Rep 75
I have to say the Cobb stage 2 map is really impressive. 8.7 100-200 without meth is also very very impressive. OP's 7.02 sec is very very impressive. |
10-17-2011, 03:39 AM | #16 |
Rep 7,377
It works on all cars.
10-17-2011, 03:49 AM | #17 | |
Rep 7,377
10-17-2011, 04:13 AM | #18 |
Rep 12
Don´t know, have to check the SD-card when i get home tonight.
BMW 135i -08
10-17-2011, 10:36 AM | #21 |
Rep 4,635
its like 73k, and he mean 180 the 60 - 130 is something crazy like 3.3 seconds
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
10-17-2011, 10:51 AM | #22 | ||||
Rep 5,876
Get that card and let's get that 60-130 section alive a bit that's a hell of a time on stock turbos by the way! Quote:
