BIMMERPOST Universal Forums Off-Topic Discussions Board Photography/Videography Circular Polarizer Filters
      10-25-2011, 11:41 PM   #1
Spoolin335
Justin Herass
Spoolin335's Avatar
Drives: X6M / M3
2015 BMW M3  [0.00]
2012 Audi TTRS  [10.00]
2012 BMW X6M  [9.00]
2007 BMW 335i  [9.00]
I am looking to pick up a CP filter but dont really know what one to get. I know B+W is high end, and Hoya is a pretty good brand.
My question is, what type of CP filter do i get?
Also, what are some good online sites to order from? I dont want a knock off so i wont even try eBay.
Looking to spend less then $130 if possible.
What is the difference between these two other then price?
I checked the Hoya website, but there is not a lot of information on their line of different CP filters.
http://www.amazon.com/Hoya-Digital-C...9599463&sr=8-3
http://www.amazon.com/Hoya-77mm-HD-C...599463&sr=8-12
      10-25-2011, 11:46 PM   #2
oneintheory
no longer a BMW owner
Drives: 2011 Ford Edge Sport
score a used B+W, imo. but if you're gonna use it on a wide-angle lens, you need to get a slim one to avoid vignetting.
      10-26-2011, 12:11 AM   #3
Caspita
Turbo Guru
Caspita's Avatar
41
Drives: 2011.99 E92 ///M
Don't go cheap with the polarizer. B&W is purely amazing, and yes I have gone through a couple of different brands that i won't name. My B&W was worth every penny, I own it in 77mm slim as well as the 105mm.
As for where to purchase, you can always try B&H Photo as well as 2filter.com
Casp
Casp Media |
      10-26-2011, 12:19 AM   #4
kamek
Drives: 2018 X3 M40i
2008 BMW 328xi  [8.20]
I've stayed true to B+W and Hoya for the most part. I think they both make quality products.
When/if buying used, be careful that you're buying from a reputable seller/store because fakes/knock-offs do exist.
      10-26-2011, 12:33 AM   #5
Spoolin335
Justin Herass
Spoolin335's Avatar
Drives: X6M / M3
2015 BMW M3  [0.00]
2012 BMW X6M  [9.00]
So i have been searching the sites listed and Amazon for a B+W filter and found that Amazon is by far the cheapest. If i buy from Amazon directly and not some seller on Amazon i should be safe from fakes.
Now, i have found that the MRC is almost a must, is this true? I am also not going to get the slim one because its not for a wide angle lens and i want to be able to slap my lens cap on without taking the filter off. From the sounds of it, i cant do this with a slim filter because it doesnt have any threads to clip the lens cap onto.
Does this one seem ok? Its $165 to my door.
http://www.amazon.com/77mm-Circular-...9600793&sr=1-4
Thanks guys for the tips thus far!
      10-26-2011, 01:01 AM   #6
Caspita
Turbo Guru
Caspita's Avatar
41
Seems pretty solid. Although the slim one doesn't come with threads at the end it does come with a type of slip over cover the protects the lens. MRC is definitely a bonus, i promise you will not regret your decision.
Casp
Casp Media |
      10-26-2011, 01:58 AM   #7
Spoolin335
Justin Herass
Spoolin335's Avatar
Drives: X6M / M3
2015 BMW M3  [0.00]
2012 BMW X6M  [9.00]
Ordered it, Thanks!
      10-26-2011, 07:45 AM   #8
Chewy734
Drives: 2006 BMW 330i ZPP, ZSP
nice purchase! The B+W is definitely worth it, imo.
      10-26-2011, 08:28 AM   #9
I have that same CPL in 77mm. Works very well. And since it's on a lens that does mostly outdoor shots (24-105mm), I just leave it on the lens. It doesn't cause vignetting on my 10-22mm, but on a lens that wide it can cause banding in the sky areas if you're not careful. Otherwise it works wonders for color.
      10-26-2011, 08:37 AM   #10
Chewy734
It causes vignetting on my 17-40mm f/4L on the 5D2. On the 20D there is no vignetting.
      10-26-2011, 04:14 PM   #11
vachss
Drives: Z4 Coupe
For future reference you might want to try Maxsaver.net for B+W filters. They are an overseas company, but have proven to be a reliable source over the last few years. In this case only a few bucks cheaper: http://maxsaver.net/B-W-77mm-MRC-Cir...NEW-F-PRO.aspx , but good to know about regardless.
      10-27-2011, 01:11 AM   #12
Caspita
Turbo Guru
Caspita's Avatar
41
Do you have the slim version, because I get no vignetting with the combo you mentioned above.
Casp
Casp Media |
      10-27-2011, 09:06 AM   #13
Chewy734
sadly, no... you are right Casp. Btw, love your blog.
      10-27-2011, 02:08 PM   #14
Caspita
Turbo Guru
Caspita's Avatar
41
Hey Thanks....just trying to help out best I can. Which blog did you check out?
Casp
Casp Media |
      10-27-2011, 04:25 PM   #15
Chewy734
both, but especially the caspmedia one.
      10-27-2011, 09:53 PM   #16
Caspita
Turbo Guru
Caspita's Avatar
41
Hey thanks...haven't updated that one in a long long time
Casp
Casp Media |
      10-27-2011, 11:13 PM   #17
kamek
Full frame FTL?
      10-28-2011, 01:27 PM   #18
Caspita
Turbo Guru
Caspita's Avatar
41
Originally Posted by kamek View Post
Full frame FTL?
I will NEVER go back to a crop sensor.
Casp
Casp Media |
      10-31-2011, 01:27 AM   #19
kamek
Neither will I . I'm a 5D2 shooter myself!
