335D Thermostats
11-07-2011, 07:49 AM | #1 |
Rep 482
335D Thermostats
Hi
Did a run down the motorway this morning and after 90miles my coolant temp was at 76c. I had the cruise control on at 70 for practically the whole trip and hardly touched the accelerator. It only went to 81 when I got off the motorway and drove for about 1 mile before parking up. Is this normal after a long drive and no acceleration? The outside temp was 1c if that makes any difference. If the stats need changing should I change the EGR and Main or do I only need to do the one? Cheers |
11-07-2011, 08:11 AM | #3 |
Rep 8,113
Sounds too cool but I don't have a 335d to compare it with.
@ Falmouthboy - you need to access the hidden service menu to see this.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
11-07-2011, 08:19 AM | #4 |
The Tarmac Terrorist
957
Rep 29,345
Drives: 997.2 GT3
The BMW diesel engines coolant temp varies so much BMW didn't fit a coolant temp gauge as they thought the varied fluctuation changes would scare owners.
997.2 GT3
11-07-2011, 08:30 AM | #5 |
Rep 565
As DXB says coolant temp does vary quite a bit. Every car I have ever had the temperature guage never really moved once warm.
76 degrees wouldnt bother me greatly as the extra cooling on the motorway due to relatively high road speeds / low temps & driving at 70 in a 335 isnt working it too hard. You would probably find it rises into the 80's on tickover due to no moving air through the rad. Changed my egr stat but made sod all difference to be honest. May have warmed up slightly quicker but made no difference to me at all. Lat year it would have worried me but now it wouldnt. Last winter mine took ages to get up to temperature (monitoring it all the time back then) |
11-07-2011, 08:42 AM | #6 |
957
Rep 29,345
Drives: 997.2 GT3
Wish I knew about the secret menu when I had mine.
Any pics??
997.2 GT3
11-07-2011, 08:45 AM | #7 |
Rep 8,113
Should find it from a search - instructions on how to get it and then what all the items are, coolant temperature is one of many.
I'm guessing LCI cars have automatic radiator louvres (blanking) ?
Ian
11-07-2011, 09:29 AM | #9 |
Rep 482
I think il leave them for now then and keep an eye on them over the next couple of months.
I had in my mind the temp should be between 88-91. Local stealers wanted £396 to change both stats and local specialist indie wanted £192. Apparently one of the stats is a pain in the arse to change. Not got any pics, will see what is like on the way home an take some Cheers all! |
11-07-2011, 09:33 AM | #10 |
957
Rep 29,345
Drives: 997.2 GT3
Cheers Jon!
997.2 GT3
11-07-2011, 11:09 AM | #11 | |
Rep 15,858
EGR 'stats often fail in the first stage element, the 70-degree opening temperature, and that causes the low range figures, typically mid 70's as the system is open circuit to the radiator and bypassing the main 'stat. Also often responsible for very slow warm up times and low mpg. When removed, you can blow through the 'stat without any or very little resistance. The second stage element (higher than the main 'stat at 90-degrees opening) becomes obsolete, as it is already out of range and messing the coolant temperature. EGR 'stat is easiest to change and will then give an indication if the main 'stat is fine, or opening a bit low. Many main 'stats in the BMW diesel engines, (BMW and Rover models) have mid 80's working temperature, with fluctuations due to load and ambient temperature. Seems a lot of main 'stats settle in the mid 80's even after a relatively short life. HighlandPete |
11-07-2011, 11:52 AM | #12 | ||
Rep 482
Thanks for the advice. I will keep an eye over the next couple of weeks and if it stays te same I will get the EGR stat changed and see if that does help. The car does take at least 15-20 miles to get well into the seventies. The wife's 118d is up to 88 in around 10 miles. |
11-07-2011, 12:20 PM | #13 |
Rep 3,923
mine started running at 76 and using more fuel whereas normally 86 struggled to make 82 changed the EGR and went back to normal you can do these diy and cost about £25 from bmw
11-07-2011, 01:15 PM | #14 |
Rep 336
Interesting post given that yesterday I was observing my coolant temp on a 60 mile round trip when the ambient temp was between -1 and +2 degrees!
It took about 20 mins to reach the early 70's and fluctuated between the lowest 68 (when I changed to DS mode) and highest 78 degrees for only about a minute! The magic number of 75 being the minimum coolant temperature that the ECU allows for a regeneration of the DPF was only held for a few minutes and I'm sure it did not stay over 75 for long enough to regen... Most of the time it hovered at 73 degrees.
Sapphire Black* Darklines* Black Dakota Leather* Heated Seats* Professional Navigation* Xenons* High Beam Assist* Hi-Fi* USB Audio* DAB* BMW Assist* Sun Protection Glass
11-07-2011, 01:36 PM | #15 |
957
Rep 29,345
Drives: 997.2 GT3
Man, how cold is it where some of you guys live... faaacckkk!!!
Sill 10+ here.
997.2 GT3
11-07-2011, 03:02 PM | #16 |
Rep 15,858
The EGR 'stat should only initially crack open at 70-degrees to keep the EGR cooler down to temperature. (It bleeds water just to heat soak the element, to govern its operation at all times). The second stage should only open the valve and mushroom head completely, at 90-degrees, after the main thermostat is in its operating range. But if the EGR 'stat is opening prematurely, or shot, it is possibly wide open from lower than 70-degrees. There is enough flow to keep the engine cool, with little chance of warming up, particularly at low loads, worse at low ambient temperatures.
Pictures of a CAD model of the EGR thermostat, I made up last winter. HighlandPete Last edited by HighlandPete; 11-07-2011 at 03:08 PM.. |
11-07-2011, 03:05 PM | #17 |
957
Rep 29,345
Drives: 997.2 GT3
Surely this part should not be going on 4+ year old cars?!
997.2 GT3
11-07-2011, 03:08 PM | #18 | |
Rep 482
Cheers |
11-07-2011, 03:13 PM | #19 |
Rep 15,858
11-07-2011, 03:34 PM | #21 |
Rep 15,858
It does surprise me. I've chatted to a Master Tech' on this issue and asked what the official line is, for what temperatures an engine should be running and where the temperature breakoff point is on the main thermostat, before BMW recommend a replacement. Nothing on their system, we looked but couldn't find a definitive.
What is apparent, the control strategy allows for a fluctuation of temperature, it can drop off rapidly, as EGR flows are also involved and cooling a high EGR ratio flow will mean a wide open ERG 'stat. I wonder if there is more thermal load, on the EGR 'stat than we would expect and it cooks up the low temperature element. Even the main thermostats are not too durable it seems, why replacements (OEM 'stats) drop to mid 80's in a short life cycle, just months with some users, I also find hard to understand. My main 'stat is running mid 80's, stayed like it for a year, so in two minds whether to change, or just leave it, if it drops no further. Regen's push it up into the 90's, so no issue there. HighlandPete |
11-07-2011, 03:36 PM | #22 | |
Rep 482
Thanks again |
