My car wont run Cobb stage 2+.
11-13-2011, 05:20 PM | #1 |
Rep 78
Like the tittle says. It starts misfiring at WOT. I switch to the regular stage 2 map and it runs fine. Any ideas? It threw a misfire code on #6 cylinder. The car is a 07 6at. Hpf intercooler, Bms intake and cpe downpipes.
11-13-2011, 05:21 PM | #2 |
Rep 7,377
how old are your plugs?
11-13-2011, 05:29 PM | #3 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
my car did the same thing. New plugs fixed it.
11-13-2011, 06:06 PM | #6 |
That guy
117
Rep 5,740
yea, my car has 36k (i bought new) with 2 hpfps, new injecters under recalls and standard maintenance and they never changed my plugs.
11-13-2011, 06:06 PM | #7 |
Rep 3,625
11-13-2011, 06:23 PM | #8 |
Some say...
239
Rep 4,296
Drives: Fresh
had the same problem, had one bad coil. Changed it and it was fixed.
On a side note, do you feel strange throttle oscillations when putting it to the floor?
I have exhaust and an intake... |
11-13-2011, 06:37 PM | #9 |
That guy
117
Rep 5,740
11-13-2011, 07:43 PM | #10 |
Rep 1,717
Drives: lifted tacoma on 38's & ducati
throttle oscillations? what exactly does that mean?
car totaled out !!AW335i, oem aero lip, m3 csl rims, oem m3 sides, vorst csl carbon trunk, tinted, lowered on H&R sport, AR DP's, Bastauck dual exhaust, BMS intake, etc
NEW RIDE white GTR! |
11-13-2011, 07:55 PM | #11 |
Rep 1,903
Drives: e92 335i 6MT
Same thing here...cylinder 6 misfires at WOT on S2+. Original plugs with 35k miles. Plugs will be changed next week. Hopefully, that will fix it. No issues running S1
11-13-2011, 08:50 PM | #12 |
twinborific
119
Rep 4,836
If your car is still under warranty, did you just bring it to the dealer with the tune installed and the code thrown? Or did you pay for a plug change? Since there is no way to throw the misfire on stock/stg1/stg2, any idea if the load placed on the plugs will EVENTUALLY manifest itself on the stock map so that it can be warrantied?
Doko ni itemo, hito wa tsunagatte iru...
11-13-2011, 09:47 PM | #13 | |
Rep 1,903
11-13-2011, 09:57 PM | #14 |
twinborific
119
Rep 4,836
I see - that's definitely not expensive. what if it's the coils tho
11-13-2011, 10:03 PM | #15 |
Rep 1,903
Well, I think its good practice to start with a fresh set of plugs as soon as you start running a tune - as you would have to change them out later anyway. If the problem still persists, then you can start looking at coils
11-15-2011, 11:13 AM | #19 |
Some say...
239
Rep 4,296
Drives: Fresh
Yes and no, I contacted them and they told me to check my DCI b/c they have seen that happen with DCI with the air filter on too far, that's all they really had to tell me about it. I have talked about it on another forum and only some are feeling it, not everyone running stg 2+ is.
