New Stock Turbos
11-14-2011, 06:11 PM | #1 |
Rep 473
New Stock Turbos
Well I was having a problem holding boost a whiles back, and finally after bringing it in to the dealer found out it was the turbos! I did think it was odd because my millage is at 30k but figured hey as long as it was covered under warranty. Only thing is now during part throttle I sometimes here the turbos spool with some kind of stutter noise? If I'm gentile on the throttle no stutter and no stutter doing WOT. My mods are DCI, PROcede v5 rev3, and AR cat-less down pipes. Any ideas?
11-14-2011, 06:15 PM | #3 |
Rep 473
Possibly but would it make sense only hearing it during part throttle? I remember I use to have this problem on my srt-4 where the car would boost creep then make the flutter/stutter noise. Curious to see if anyone else hears this?
11-14-2011, 06:17 PM | #5 |
Rep 473
Yes I did. And it was worth it.
11-14-2011, 06:27 PM | #6 |
Rep 799
Drives: 08 335 silverback
prob wastegates actuator arm needs adjusting, mine did the same thing
FBO...METH...BIG TWINS
11-14-2011, 09:45 PM | #7 |
Rep 473
11-15-2011, 01:15 AM | #8 |
Rep 957
is the sound your speaking of like a hissy blow off sound. like air escaping a little leak, like the pssss sound you would make toward a cat lol. i get that sound on partial throttle on and off and if i give it just a TAD more throttle it stops. its like just at little certain points. like on and off choppy loud windy hissing lol.. if so, i have it to, but see no problems. i hold boost perfectly. all good
07 335i- SOLD, and will be missed...
Parts for sale- PWM meth kit, M steering wheel, M shift knob, perforated e brake handle |
11-15-2011, 06:34 AM | #9 | |
Rep 799
this is wastegate rattle... on a cold start it sounds like a vtec honda, and until it is warmed up you get the rattle on acceleration and when you push in the clutch and let off the gas, but when the car gets warm it almost goes away, if this is what your experiencing, it is the wastegates and dont let BMW tell you it is normal, minimal noise is normal, but when it makes you want to loose your mind, it is not
11-15-2011, 09:27 AM | #11 | |
Rep 473
11-15-2011, 09:29 AM | #12 | |
Rep 473
