Should I replace the flywheel?
11-16-2011, 01:05 AM | #1 |
Rep 1,065
Drives: RB PWRED E90 N54 6MT
My clutch is slipping badly and will like to replace it with the ACT Street.
For those of you running aftermarket clutch, did you also replace the flywheel? |
11-16-2011, 09:31 AM | #2 |
Team Zissou
3084
Rep 10,198
I got the SPEC lightweight aluminum flywheel with my spec clutch. their flywheel is 12 or 13lbs compared to 30+lbs stock. The car revs very quickly and its a great combo, but because of this there is clutch rattle. Nothing pressing in the clutch pedal at the stoplight can't fix but next time I do it I'll be getting something that makes less noise
11-17-2011, 03:22 PM | #4 |
Rep 1,065
RB Turbo/Procede V5/Vishnu PWM Meth Injection Kit/Vishnu DCI/AR Catless DP/AE Performance Exhaust(Sold)/Helix FMIC/Forge DVs/Rixster Vent Boost Gauge/Wavetrac LSD/KW V3/ACT Street Clutch Kit
11-17-2011, 03:44 PM | #5 | |
Rep 1,809
Don't waste your ACT clutch. |
11-17-2011, 08:50 PM | #7 |
Some dude
92
Rep 1,780
Same here. The dual-mass flywheel is not bulletproof, could be prone to failure. With the labor it takes to R/R the trans, the flywheel should be put into the budget to save headaches in the future. Especially if you're tuned.
RRT
E92 335i/6MT with stuff and things |
11-17-2011, 11:07 PM | #9 |
Some say...
239
Rep 4,296
Drives: Fresh
8lbs? not THAT much lighter as opposed ACT which is 20lbs lighter. OP I am replacing my flywheel with the streetlite one and stg2 clutch soon. If you haven't done it yet I will let you know how it feels. With my other cars I have always replaced the flywheel, you might as well since its right there. Could save you a major headache later.
I have exhaust and an intake... |
11-18-2011, 05:20 AM | #10 |
Rep 2,563
It may not fit. There's a discussion in another thread - someone tested it with a 2006 build car and it didn't work. It may work for newer build cars, that needs to be verified though.
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
